ryan lang Posted November 12, 2012 Posted November 12, 2012 id get the head skimmed depending on how big a build your doing, the standard headbolts can be used more than once Quote
StuDoc 72 Posted November 12, 2012 Posted November 12, 2012 Dave. Get your head skimmed, get a new gasket and head bolts.Anyone who says otherwise is talking pish its not worth the hassle trying to re-use this kinda stuff. I assumed you had already had all this done or i woulda said in the 1st place. If you dont know where to get it skimmed ill show you a place in dton ive have 100s of head done there. Quote
daveEP Posted November 12, 2012 Author Posted November 12, 2012 its not a masive build mate just stripped it down to make sure all was good. standard internals & tongs ct9. Quote
daveEP Posted November 12, 2012 Author Posted November 12, 2012 much we talkin for gettin the head skimmed stu. didnt know there was a place in dton that does it was lookin at newmarket engineering in stirling lol. aye a think i am goin tae get it skimmed, new gasket & head bolts. Quote
StuDoc 72 Posted November 12, 2012 Posted November 12, 2012 30 bangers or sumthin. Aye head bolts cud be used again at a push but re using a gasket is a no no.Even still id never re use bolts its really no worth the hassle for a few quid. Quote
AdamB Posted November 12, 2012 Posted November 12, 2012 Getting the head skimmed is not compulsory, as long as it is straight then it will be fine. No need to get taking material off which doesn't need to come off. Its harder to put material on than it is to take off.That said, it is advised to atleast get it checked, if its going to a machine shop to be checked, may as well get it skimmed for the sake of like 20 quid.The head bolts are TTY, do NOT re-use them! Once they have been torqued they would have gone past their elastic limit, next time you use them they will NOT provide sufficient clamping force and you may even end up snapping the head off the bolt whilst torquing.ARP bolts on the other hand can be re-used, but need to be checked for stretch. Quote
daveEP Posted November 12, 2012 Author Posted November 12, 2012 (edited) cheers adam that clears up. been doin my homework today and i've sorced a new gasket, heads getting skimmed (£30) and il get onto idrees for new head bolts. job done!! I HOPE lol. ;) Edited November 12, 2012 by daveEP Quote
daniel_g Posted November 12, 2012 Posted November 12, 2012 Glad to see it wasn't a major problem mate. As for newmarket they guys do top notch work, my work and a few other garages in the area send all engineering work up to them with no issues.My 4e block and crank will be getting sent up to them at some point too. Quote
daveEP Posted November 12, 2012 Author Posted November 12, 2012 yeh mate been told there good at what they do. a managed to get a company down this way to skim the head witch is not to bad. cant see it happning again once thats been done along with the new head bolts and gasket. Quote
daveEP Posted November 12, 2012 Author Posted November 12, 2012 took the oil line for the turbo off today and the oil was like custard. think il need to use shite oil for next start up to flush ma engine out & empty it again then put the good stuff in. Quote
PaulStarletSR Posted November 13, 2012 Posted November 13, 2012 Av got veg oil in ma kitchen a dont need davey :-p Quote
daveEP Posted November 14, 2012 Author Posted November 14, 2012 had a good look around tonight and i have water/oil sitting in my inlet. what the fuck. how has it manged to get in there? any clues? Quote
funny onion Posted November 14, 2012 Posted November 14, 2012 had a good look around tonight and i have water/oil sitting in my inlet. what the fuck. how has it manged to get in there? any clues?Have you got the vac/coolant lines on the throttle body on the right way round? Quote
AdamB Posted November 15, 2012 Posted November 15, 2012 Have you got the vac/coolant lines on the throttle body on the right way round?x2, most common problem is swapping the hoses the wrong way. Quote
daveEP Posted November 15, 2012 Author Posted November 15, 2012 yes im positive. two vac hoses are the two that are closest together to each other and go down to the steering rack (round a bout) am i right?? Quote
