Patches Posted December 6, 2012 Posted December 6, 2012 Not sure if anyone else feels the way I do but why is everyone stating their power at the flywheel? (aside from the obvious fact it would be bigger)Does anyone else feel its kinda pointless? because at the end of the day its what you have at the wheels which is important surely?Thoughts? Quote
_shaun_ Posted December 6, 2012 Posted December 6, 2012 yea just because its bigger number think as socks put it. "its just more willy waving points" Quote
Ryan-11 Posted December 6, 2012 Posted December 6, 2012 I agree, maybe we could add whp to the leader board? Quote
AdamB Posted December 6, 2012 Posted December 6, 2012 (edited) Would prefer to see WHP tbh, because some people lose a lot through the drivetrain, others don't, its a good way to see whos done what to ensure they get maximum power at the wheels.Also added to the fact that dyno's read WHP then calculate the fly hp. Edited December 6, 2012 by AdamB Quote
Jamie_VF22 Posted December 6, 2012 Posted December 6, 2012 I agree, maybe we could add whp to the leader board?Good idea ryan im sure matt will add it to the leaderboard pal Quote
Patches Posted December 6, 2012 Author Posted December 6, 2012 Infact, not to sound like an idiot or anything but standard bhp for glanza is 130-135 at the wheels or flywheel? Quote
AdamB Posted December 6, 2012 Posted December 6, 2012 Flywheel mate, marketing stunt to make people buy it Quote
mattyD Posted December 6, 2012 Posted December 6, 2012 how much do you lose through the drivetrain percentage wise?would things like lightweight flys obviously change the WHP? if so, how can this be calculated depending on what fly you have/how much it weighs etc?? Quote
AdamB Posted December 6, 2012 Posted December 6, 2012 Loss through drivetrain depends on the driven wheels, a 4wd car will lose more than say a FWD car. Also depends on the placement of the engine, if you have a transaxle you'll lose less than if say you had to transfer the power from the front to the rear.Normally for a FWD transaxle will be around 10-15% loss. Your clutch assembly does affect it.Like I said, Dyno's measure the WHP and the fly HP is then calculated. Quote
Weyro Posted December 6, 2012 Posted December 6, 2012 Im curious, if power is lost, where does it go? Heat? Quote
morgey Posted December 6, 2012 Posted December 6, 2012 heat, ratio's, drag (bearings, friction from meshing gears) weight of rotating parts blah blah, some boxes are looser than others.the difference between my 2 dyno's i made 8hp fly, but 10-11hp wheel. not much but that means my newer box is slightly more effiecant, maybe because its newer, or has different ratio's or its higher milage im not sure. Quote
Starbo Moorley Posted December 6, 2012 Posted December 6, 2012 Whp ftw ! Catches people out when you tell em whp. Quote
Ricky@Race-Tech Posted December 7, 2012 Posted December 7, 2012 Very true, whp is better, however just remember lots of people with mods will have less whp than 130. Standard cars are around 110whp. Quote
