TrisK Posted December 11, 2012 Posted December 11, 2012 i think youll struggle without massive arch work.off the top of my head the closest person is Dean@RWwith 8J et0, so move it in 30mm and thats what youve gotAlthough not sure what strut clearnace is like, either way, arch work will be neeeded. Quote
Beastmode panda Posted December 11, 2012 Posted December 11, 2012 There's not much point in trying to stance a starlet cause they aren't independant suspention, like hondas are. With hondas for example you can get camber arms and all that jazz.. But with starlets being on a beam you'll never get camber on the rear to be able to pull it off and look good. Idrees has i THINK 8j grid drifts on his starlet and it looks ok, just the fitment is a massive issue really. TBH with a starlet i'd be going for a mean aggressive track stance look with big beefy tyres and wheels that fit with some aero parts.Just my 2 pence, but stancing a starlet, successfully, will never happen. Quote
Josh@TunerLifestyle Posted December 11, 2012 Posted December 11, 2012 i had 8j et0 too. need ALOT of work to make them fit. even with coilvers and arches rolled its not enough. will need a big flare Quote
Ryan-11 Posted December 11, 2012 Posted December 11, 2012 There's not much point in trying to stance a starlet cause they aren't independant suspention, like hondas are. With hondas for example you can get camber arms and all that jazz.. But with starlets being on a beam you'll never get camber on the rear to be able to pull it off and look good. Idrees has i THINK 8j grid drifts on his starlet and it looks ok, just the fitment is a massive issue really. TBH with a starlet i'd be going for a mean aggressive track stance look with big beefy tyres and wheels that fit with some aero parts.Just my 2 pence, but stancing a starlet, successfully, will never happen.I take it you aint seen coreys glanza then? Quote
TrisK Posted December 11, 2012 Posted December 11, 2012 I take it you aint seen coreys glanza then?Corey had the whole car widened. You also can't get camber on the rear easily on a starlet due to the axel/stub axel config Quote
Ep91Ben Posted December 11, 2012 Author Posted December 11, 2012 Yeah think ill leave them then was just wondering as saw a nice set of wheels think ill go for the more track look tbh Quote
Ryan-11 Posted December 11, 2012 Posted December 11, 2012 Corey had the whole car widened.You also can't get camber on the rear easily on a starlet due to the axel/stub axel configRbz was sayin "Just my 2 pence, but stancing a starlet, successfully, will never happen" imo it has been done, rolled and pulled arches ect ect, it has been done! Quote
Beastmode panda Posted December 11, 2012 Posted December 11, 2012 I take it you aint seen coreys glanza then?I have, i think.. Is it an n/a ep91?If so, i bet the wheels aren't 8j. And like Trisk said he had a lot of work done by the sounds of it.It's all because starlets/pugs/saxo's and the likes all run on a rear beam. If they were independant then you'd have no issues. Quote
TrisK Posted December 11, 2012 Posted December 11, 2012 I have, i think.. Is it an n/a ep91?If so, i bet the wheels aren't 8j. And like Trisk said he had a lot of work done by the sounds of it.It's all because starlets/pugs/saxo's and the likes all run on a rear beam. If they were independant then you'd have no issues.Corey's is a glanza. And I think they are 8j et25 iircThe beam isn't the issue. As camber shims would work if the stub axle wasn't welded to the beam Quote
Corey Posted December 11, 2012 Posted December 11, 2012 (edited) et20 8j got the arches rolled and flared if thats any use Build here if you want to see what was done http://www.toyotagtt...e=25171&catid=6 Edited December 11, 2012 by Corey Quote
TrisK Posted December 11, 2012 Posted December 11, 2012 et20 8j got the arches rolled and flared if thats any use Build here if you want to see what was done http://www.toyotagtt...e=25171&catid=6Didn't you have the whole rear quarters pulled out by quite a lot? Quote
Amjad Posted December 11, 2012 Posted December 11, 2012 I'd love it if I can get my GT arches pulled anything like that! Quote
Corey Posted December 11, 2012 Posted December 11, 2012 Didn't you have the whole rear quarters pulled out by quite a lot?Think just over a half an inch dude Quote
Matt1878 Posted December 11, 2012 Posted December 11, 2012 et20 8j got the arches rolled and flared if thats any use Build here if you want to see what was done http://www.toyotagtt...e=25171&catid=6im sorry but this is fucking BEAUTIFUL! Quote
