goin puting in my jam ecu just asking questions so i dont do anything stupid lol
do i have to disconnect the battery or anytng ?
Edited by ep-beast
disconnect the batttery
swap ecu over
connect battery back up
start car and let idle for 10 mins or so
then take out for a few drives gently increasing the boost levels with your actuator until you have reached 1 bar or whatver you want to run............
I think thats it.............:)
No plug and play. Some people will say let it idle for 30 minutes when you first put it in, I never did I wouldn't waste the fuel and I was fine, whip up the boost and go enjoy!
Worth noting a number of people have done this and had to reset and idle it again, saves time getting it done first anyway rather than having to go back and do it again
What he said :) i had to re set mine when i had the Blitz fitted.
John
Yea I would let it sit I never did and forever having problems until I read what sum of the lads said and this changed the car totally
Do it once mate there's no harm
1 - remove negative battery terminal,
2 - remove efi fuse.
3 - Remove stock ECU.
4 - install the new ecu.
5 - re-insatll efi and then the negative battery terminal.
6 - fire it up and leave it to ide for 15-20 mins,
7 - start driving but not boosting over 0.7bar for the first 100-200 miles.
8 - Turn the boost up to desired setting.
I noticed AFR was all over the place for the first 150ish miles it was running very rich when driving hence why i kept boost at 0.7 bar.
AFR became more steady after the 150ish miles thats when i turned the boost up.
