Spoon_tuned Posted January 8, 2013 Posted January 8, 2013 hey guys i'm getting an annoying creeking noise coming from the front end when turning or sometimes just pulling off any ideas...i have changed the front cv joints recently so its not them cheers Quote
morgey Posted January 8, 2013 Posted January 8, 2013 One of the bushes, anti roll bar or wishbone at a guess? Quote
jordan walker Posted January 15, 2013 Posted January 15, 2013 I have started getting the same noise ever since i fitted my new coilovers my guess is the top mounts Quote
The Toffinator Posted January 15, 2013 Posted January 15, 2013 Is it mainly when your at low speed? Topmounts can creak on them. Worth greasing them to death before fitting them Quote
jordan walker Posted January 16, 2013 Posted January 16, 2013 Yeah like if i slow down to go up my girlfriends farm when i turn up the lane the pot hole kick fuck out of my car thats when it does it most Quote
Addymk2 Posted January 16, 2013 Posted January 16, 2013 I had a creaking when the rear strut brace worked itself loose, might be worth a look! Quote
Spoon_tuned Posted February 13, 2013 Author Posted February 13, 2013 Is it mainly when your at low speed? Topmounts can creak on them. Worth greasing them to death before fitting them that could be the answer thanks Quote
Spoon_tuned Posted February 13, 2013 Author Posted February 13, 2013 right guys few of you have said top mounts which is a really good shout..i'll take suspension off grease the top mount and put it back on see if it makes a difference plus i just had my MOT and the guy said come here have a look at this so i did and where the wishbone is bolted to the chasis the bolt is slightly loose and wont tighten anymore without getting looser first so that could be an issue to thanks again lads youve been a great help Quote
jellybaby Posted February 14, 2013 Posted February 14, 2013 right guys few of you have said top mounts which is a really good shout..i'll take suspension off grease the top mount and put it back on see if it makes a difference plus i just had my MOT and the guy said come here have a look at this so i did and where the wishbone is bolted to the chasis the bolt is slightly loose and wont tighten anymore without getting looser first so that could be an issue to thanks again lads youve been a great help With the bolt sounds like someone has crossed threaded the hole if I was u and could get a tap and die set I would re tap the hole and die the bolt as eventuly it will fail if not sorted Quote
