Thinking about ripping the abs out whilst the engine and box is out, not a massive fan of it and it looks nasty in the bay.
Has any got a removal kit I could buy? Pipes, joiners etc??
Also is there a guide on how to do it?
I can't imagine it being that hard.
Cheers
Lewis
Ah makes sense, I'll have to do a bit of digging and see what's exactly needed, cheers
Edit: is the person on here that took the parts, might be worth asking them what they took.
Edited by Lew91
Just to add, when I did an ABS delete on my mates glanza, I had to change the "P" Valve (Brake proportioning valve) , marked 3 on the EPC diagram above, to the non ABS type found on an N/A uk starlet, as the non ABS type "P" Valve has one extra port which from memory is for the drivers front caliper brake line, which is not on the ABS type "P" Valve.
Edited by GreaseMonkey
