Glanza V From the Caribbean..TIME SLIPS ADDED First Drag meet
Hailing from the Caribbean island of Barbados
This is my second car my first was a 1991 gt turbo starlet with a gt28r everything else was stock.
Now i own a 1998 Glanza S converted to a V.
Got in an accident painted her from grey to red.
Engine Specs:
5efe Block
Modified Equal Length Intake 5efe Intake Manifold
JDM 5efhe Connecting rods
Toyota OEM Connecting rod bearings
Toyota OEM Main crankshaft bearings
Shaved stock 4efte pistons 150, 150, 160, 148 Compression de-oiled.
Greddy TD05H-18G Rebuilt by Mings Performance Tuning
HRF Exhaust manifold
Generic 44mm V-band Wastegate Vented to atmosphere
Fully Ported and Polished head done by StouteSports
Stock Valves
Stock Valve Springs
Camshaft Lift and duration profile Unknown
AEM EMS4 Wired in and tuned by Robert Bishop of RB Performance And Ras De Truner
Aquamist Water Injection (Not fully hooked up as yet)
Coil On Plug Ignition taken from the RunX
550cc Injectors
Walbro 255lph Fuel pump
3Bar Map Sensor
TurboXS Manual Boost Controller
Standard 1991 GT Turbo Gearbox (Non LSD unfortunately and in need of a rebuild)
NKG Plugs bought from any gas station
Half size double core radiator.
2.5 downpipe into 3 inch V-band full exhaust
2.25 Intercooler piping
HKS SSQ BOV
29’”x9”x3” Intercooler
Magnaflow 3” Flex Pipe
Magnaflow 3” in 4” out Oval Barrel
Suspension Front:
KYB EXEL G
TRD Lowering Springs
Suspension Rear
Koni Rear Shocks
Unknown rims 16” (need replacing)
Proxes 4s
Standard Brakes (Needs Upgrading)
Electronics and Monitoring Apparatus:
HKS Type 1 Turbo Timer
Temporary AutoGauge by Auto Meter Monster Tachometer
Auto Meter Sport Comp Oil Pressure Gauge
Auto Meter Sport Comp Boost/Vaccum Gauge
AEM UEGO Wideband Gauge
Aquamist Water Methanol Flow Gauge
4” MTX Front Speakers
Cadence 6x9” Rear Speakers
12” MTX Subwoofer In Box
1000 Watt Monoblock Amp
600 Watt 4 Channel Amp for all midrange
Pioneer DVD Touch Screen Deck
Exterior
Stock bumpers and side skirts
Stickers
Tint removed
Toyota 3E5 Paint code.
Street Trim:
Full Interior
12PSI on Pump Gas
Rev limit around 7000RPM
Full Sound System
Bottle of Oil
Bottle of water
Spare Tyre
Wind Up Jack
Race Trim:
Driver seat
20+ To Unknown PSI on Q16
Rev Limit 8000rpm
Installed LSD gearbox and ACT extreme pressure plate on sat.
419651_10151661007504112_1796145962_n.jp
Started off with Greddy Tdo5 16G and ebay t25 flanged manifold
3 inch down pipe
550355_10151489745139112_1854414707_n.jp
First intercooler pipe for hot side
178216_10151489743219112_1821239647_o.jp
131775_10151489742959112_1214718635_o.jp
Mocking up cold side of the intercooler
bottom half of down pipe bend by the sump construction
Double 90 pipe used for down pipe
302734_10151489734504112_1150755886_n.jp
Fabricating IC piping
135829_10151489736649112_1972276974_o.jp
DAY TWO
Making oil feed connection for turbo.
622791_10151489734974112_2032750843_o.jp
12PSi actuator found out to be fualty car went to 17psi and boost cut due to ecu failsafe
3 inch exhaust flex pipe on
281014_10151489781959112_1443617750_o.jp
All V band connections for easy removal of turbo set up or gearbox.
Waiting for bov hole to be drilled
171925_10151489778879112_1720632280_o.jp
326857_10151489777784112_1695819805_o.jp
Off to aluminum welder for serious fabrication
135861_10151489804554112_1042837618_o.jp
Hotside trying to avoid rubbing the chassis
664518_10151489801674112_1505699320_o.jp
Edited by BajanHitman
Too lazy to mod this cold side pipe any more so racing radiator goes in
Took the car to get some more exhaust ran
Build director looking at exhaust height
had to heat the pipe and angle it up some more
177374_10151492093974112_1260827460_o.jp
Completed to the back wheel. had to crush bend to reach it but changed it when i bought a U J bend locally
Wiring in or splicing in AEM EMS 4
Changed the intake manifold from stock 4efte to modified 5efe equal length runner with extended collection chamber for more low down to mid range torque.
Manifold discoloration came from starting issues had serious timing errors. Car would not start and idle properly had the wrong teeth count in the setting
622682_10151493521419112_2028336072_o.jp
Turbo set up off new one acquired.
603990_10151517795529112_1283176808_n.jp
Went for sale
Cleaning the head for port and polishing
534627_10151517794724112_2099727877_n.jp
148490_10151517792804112_2059165320_n.jp
Aquamist water meth kit install
Convertng 2.5 down pipe off turbo into existing 3 inch v band connection
189614_10151524221679112_2024889677_n.jp
546999_10151524216404112_1125717155_a.jp
Head work begins
643948_10151524218869112_1027378219_n.jp
553746_10151524223229112_1425723237_n.jp
553895_10151524223779112_2050595176_n.jp
559029_10151524218014112_1896421164_n.jp
Cleaning stock valves
302820_10151524217019112_1184123720_n.jp
540112_10151524216729112_2043084170_n.jp
Shaving stock pistons to lower compression
643943_10151524271304112_1240175343_n.jp
New turbo setup
Greddy TDO5H-18G 2.5 down pipe 44mm external wastegate on HRF exhaust manifold.
543076_10151524221924112_2146559632_n.jp
575247_10151524219159112_2020174484_n.jp
Head back on with manifold awaiting to find shims for the 270-272 or 274 cams not sure what they are.
526348_10151524220269112_1782764478_n.jp
Underside before oil return hose attached
Pre race day. AC parts removed (they were never working in the first place)
Had to adjust this pipe it was angled down too much didnt look uniformed up front
Manual boost controller installed. Solenoid not installed yet that will be sued as secondary boost controller as a fail safe
224818_10151577811839112_1185816213_n.jp
Before swapping to Coil On Plug setup
On my way to get exhaust fixed back strap broke had excess weight in the back
553119_10151606410904112_2143430775_n.jp
My tuner/ build director/ fabricator's car
does 550whp pump gas no water meth so far
262669_10151606413889112_1418876533_n.jp
Annoying noise if it hitting
545105_10151606417424112_1056818717_n.jp
407902_10151606418479112_1733380529_n.jp
734296_10151606419144112_1866073450_n.jp
603217_10151606419749112_2106853590_n.jp
602682_10151661007269112_1954033255_n.jp
Had some fuelling issues race day car was leaning out on high rpm at 16psi we tried changing fuel rail, injectors, pump. then we we installed a fuel cell with external fuel pump. Turned out to be a setting within the LSD itself.
432250_10151548299384112_2105482666_n.jp
Boost, oil pressure, wideband, water meth flow guage
Had spark blow out at 16psi change to coil on plug set up was quite simple.
532642_10151548303159112_2100725678_n.jp
481760_10151316524058162_2076414740_n.jp
Yeh same guy wid the evo and my mechanic believe in those NA 5efe equal length manifolds once modified correctly by extending the collection chamber after the throttle body. Saw it done in Jamaica. Guy wid the evo had a Gi GT with built 5e engine he experimented with 5efhe acis manifold, 20v individual throttle body turbo manifold, 4efte manifold and this one according to his dyno figures produced the most low down mid range torque while still flowing great upstairs. Car did 318WHP @ 18PSI on same Greddy TDO5H-18G cant remember the rpm with cams. I'm hoping to replicate anywhere near those figures.
I need forged pistons and rods but cant afford them right nowl.
Forgot to mention my last mod was changing from ACT heavy duty pressure plate to ACT extreme pressure plate with stock clutch. Installed Dif gearbox with what I believe to be an aftermarket 1.5 LSD. It crunks under slow turns when on throttle or parking but doesn't if off throttle and i can feel it disengage when i lift. (bought the box off a hit gt starlet)
Car was hit so hard it snaped the bracket mout off the gearbox itself. Had to get mechanic weld back up the spot with aluminum then I filed it down and drilled and tapped it and reattached the mount.
554388_10151658859229112_1430935748_n.jp
Had an annoying water pump pipe leak and an even more annoying ghost radiator pump leak. Pressure tested the radiator no leaks. So while the box and starting motor was off i undid the ten at the back of the block and pulled the pipe that goes into the water pump off, cleaned it with sand paper and put in a new seal and put a healthy serving of black gasket maker on it.
NO LEAKS YIPPEEE
Old box off
523255_10151658874469112_1797250035_n.jp
Driving experiences so far. We try to tune the car during the day in the hot sun cause thats when it will do most of its racing and driving. First day on the Greddy T517z car would not going to 17psi by 4500rpm. We later put a compressor on the wastegate to realise it was not working it was leaking badly. Got a 12psi spring from my friend which worked fine. Car drove at 16psi on Q16 race map rev limiting at 8000 rpm felt unreal this is without the lsd box.
After turbo change to the Greddy TDO5H-18G car was tuned to 16psi but would go no further because of a leak by the throttle plate itself. Changed that and did pressure test then tuned to 20psi on Q16. Then went back on pump gas 12 psi with timing pulled back. Car felt great in first and second gear and would wheel spin constantly but third gear felt lazy like it needed more boost as my compression is so low. Did a 2nd gear pull wid a 4g63 and kept up with him till third when he pulled and vanished. But his words were if i up my boost he is going to go and spend money in parts because I'm not to catch him lol.
Since then turned up to 16psi felt great. Then after the LSD box installation i swear my accel cable feels stiffer. But way less wheel spin i would get in first and if i flat my foot in second when it gets upstaris fresh wheel spin but not third.
This only means one thing for me...............MORE BOOST. Car feels seems like its covering more ground but with less rpm I think. I'm new to this so time will tell.
There is a racing event on the 16th Feb but I'm broke but I want to compete to see what times i get.
On Friday going to test, turn on and tune the car with the water meth. Have had a 2.5 gallon can of meth there waiting for the longest while.
Most common water meth kit here is AEM then snow performance or maybe devil's. I got my aquamist second hand. Doesn't come with a pump so i had to source that outside. What i like about the aquamist is it has a flow guage. to show u exactly how much water meth you are spraying. Unlike the AEM which you have to purchase the gauge and sensor separately.
Really pissed off at this HRF manifold. This is the third time I am welding it and this time was horrendous.
Even the brace itself snapped. When i cut it off to get room to weld the manifold it could be seen that the brace was barely tacked on at the top
Where it was previously welded
New crack top right corner of pic
Engine needs a wipe down
Turbo and mani back on.
Temp brac till a proper manifold can be made.
Some previous images of car when it first got painted and before the paint and the reason for the paint. On some borrowed rims they are awesome OZ
Alleggerita HLT
Before the paint job
Previous turbo setup
Reason for my paint job
Thats me on the sidewalk kissing the levin
My first car
431543_10150853398504112_2098480516_n.jp
424519_10150853400049112_1542549490_n.jp
One of my previous tubular manifolds would love it back now
421352_10150853460729112_1217987893_n.jp
in my opinion better design and build quality than my present hrf
Parked next to the best starlet that black gt has bigger valves, headwork, more aggressive cams than I do.
bored out fully forged and everything lightened. Runs a haltech I think.
My car before it was detuned and some parts removed. Made 264whp on the dyno years ago.
Superb mani
When i used to rock a Garrett GT28RS
Both setups were mine.
GT28Rs and GT28R T3 and T25 Flanged one was stock radiator friendly
This HRF really has me disturbed. I need back my original manifold setups. Gonna get the guy that made both of those old ones make a new one my present turbo.
We have no choice but to fabricate or order off ebay. Parts here are expensive.
My intercooler and intercooler piping came from EBAY Godspeed. 109 and 78us
3inch double 90degree ehxuast pipe came form ATPturbo.com Fuel pump came from ebay i think as well or a source in the US along with the magnaflow exhasut. Flex pipe cost 60bds on ebay but here it cost 265bds. Made sure i ordered the ic piping with the bends i needed which was as many 90s as possible or U bends.
Finally got my timing set back correct today. Set it yesterday using the timing guard but forgot i have on the 4e timing cover which differs from the 5e so I had to manually find TDC and mark it on the guarge then mark ten degrees on the guard and lock the AEM timing wizard on that mark. car feels normal again. Getting slight sputter upstairs thinking its noise interference with my wiring have to check that out. Racing is 16th FEB need 380 to race dunno if i will get it but I want the car ready for sure. Thanks for the support guys.
  • 2 weeks later...
My first Dragg event. It wasnt as easy as I thought it would be. The lights need getting used to. And I was never a good launcher lol. Car was tuned the friday night and I got to practice moving off the morning at 7. Burst a tyre
I need way more seat time. Car was tuned the friday night on half shell half 109. Up to now I cant tell you what psi it was on or what afr cause I had no time to even look that side.
My fastest time was 8.8 vs Manimal and that was due to me loosening up a lil.
At one point my gear selector cable came off I had to pull off and place it back on.
Was so nervous i could not remember what a 4 looked like even put on the 3 backwards
My fastest time slip. Left the line at 8200rpm 2nd Gear no feathering
Think its quite plain to see my reaction time and launch technique needs loads of work.
  • 1 month later...
  • 3 weeks later...
