Turbo 4efe or buy 4efte
Inlet manifold/injectors/rail/fpr would be my assumption from a glanza.
Aswell as the oil filter mounting so you have a feed and return for the turbo.
And 100% some form of mapping.
Thats a minimum that I would of thought of from the top of my head.
EDIT: Also the manifold, turbo, downpipe, intercooler etc etc etc.
Edited by Addymk2
Jay over on TGTT done this to a JDM 100ps 4E. He swapped over a few bits and bolted on the ct9, its still going strong now and pulls very well so I'm led to believe. Has been done nearly 2 years I think. He just ran the turbo ecu and injectors.
This is the plan for my current 4e as the rings are gone on it, my only questions are, do the fte rods fit straight to the fe crank, I've heard theyre the same but would like some confirmation and whats the difference between the fe and fte head?
  On 2/16/2013 at 11:15 PM, funny onion said:
Sam and a lad from our way turbo'd a 4efe and after swapping the relevant bits like oil filter housing, sump, etc it ran fine at reasonably low boost but the lad ran it out of oil :/
LOL whoopsie!
