Got the car dynoed on Friday and made the below power at 1.5 bar, pretty disappointed was hoping at 1.5bar would be 270 plus. Mapped on 95 ron, what are people's thoughts?
mine is at 239bhp at 1.2 bar and ive seen alot of people get about that at 1 bar on td04 but my injectors are maxed out so i need bigger ones lol
yeah that is a tad low, i also thought running a TD04 at 1.5 wasnt a good idea as its past its efficiency envelope after 1.4bar, it will just blow more hot air.
Is the motor forged?
i think a dyno run without afr is a waste of time tbh. the graph is a bit up and down was it spinning on the dyno?
Was on the way home from being mapped and called in at the dyno on the off chance, assumed it was fueling fine and just wanted a figure to give me good weekend lol, never considered i would need to find out why they figure was low, heinsight and all that.
Didn't seem to be, but on the same rollers a few years before it did the same thing on a different engine and map.
Had it looked at by Chris Carson and also sent the map to the guy who built the engine (moved to canada before I could get it in) and it turns out a lot of timing has been pulled at the top end that there was no need for, so going back to Chris when we get a dry night to get it sorted.
