jason_l Posted February 20, 2013 Posted February 20, 2013 Hi Everyone, Well got the thing put together and rolled it out of the workshop. Tried starting it but it just revs up and down without me touching the throttle. I hope its a quick fix as i really want to drive the thing tomorrow morning, even if it is just around the carpark a few times at work. Will post up a video when i get in but does anyone have any idea's??? Have had a little look over the inlet manifold and everything seems ok. Im guessing its something like throttle position or timing or something. Any idea's would be masively helpfull. Thanks all, Jason Quote
ryan lang Posted February 20, 2013 Posted February 20, 2013 deffo sounds like a vacuum leak dude Quote
jason_l Posted February 20, 2013 Author Posted February 20, 2013 http://static.photobucket.com/player.swf?file=http://vid920.photobucket.com/albums/ad42/demon_buggy/video-2013-02-20-17-43-44_zps6d179a46.mp4 Quote
turbo Grant Posted February 20, 2013 Posted February 20, 2013 If it revving up and downi wouldn't say it's a vac leak whats the management on it? Quote
jason_l Posted February 20, 2013 Author Posted February 20, 2013 Standard ecu.Also has race tech inlet, standard ct9, very short exhaust, hks actuator. Quote
Addymk2 Posted February 21, 2013 Posted February 21, 2013 Check the vac pipe from your inlet manifold to dump valve if you have one mate And if that doesn't work try blanking off the BOV all together, I had this with a dodgey baileys where the spring was saggier than a witches tit Quote
Amjad Posted February 21, 2013 Posted February 21, 2013 He's sorted it for now, think it was a slightly open throttle causing the issue Quote
