Guest Enzo Posted November 30, 2005 Share Posted November 30, 2005 glanza ownership is amazing but i thing ive done something ideotic,after the wknds activitys i had a heafty treck to get home, petrol light on, pulled into then nearest station, a shitty jet garage with no super so poured in a fiver of 95ron unleaded,everything was fine for a while, then the car lost almost all of its power and sounded asif it was running on three cylinders(like a very ruff flat four sound), didnt sound healthy atall, sounded well weared,limped to the nearest station with super, filled it up and initialy nothing improved, started and stoped the car on different ocasions so the ecu would pick up on the super unleaded and eventuealy its got better, the car idals normaly and pulls cleanly now but not all the time, some times i go to boost it and its asif the engine hits a brick wall and and stays ant the same revs even thought all three boostlights are on, and starts making the same sounds again?can anyone shed some light on whats wrong? Quote Link to post Share on other sites
BlackTarw Posted November 30, 2005 Share Posted November 30, 2005 Sounds like your car doesn't like the cheap stuff!Has your car been retuned for our lower crappy petrol? There's a big octane difference in average petrol in Japan and our premium stuff. Really a jap import should be running on Optimax AND octane booster but most ECUs can handle a couple of points difference to Optimax but premium, probably not.I'd suggest putting some octane booster in the tank and take it easy for a while to see if it settles down.try not too boost too much, if it's knocking and you're boosting you can knacker you engine. Quote Link to post Share on other sites
Guest Enzo Posted November 30, 2005 Share Posted November 30, 2005 do you think thats what its doing then "knocking"is that the same as detonating?sorry if these sound like stupid questions Quote Link to post Share on other sites
Simon Posted November 30, 2005 Share Posted November 30, 2005 Check your plugs and possibly leads mate but it sounds like plugs to me easy DIY job to change them.Simon Quote Link to post Share on other sites
lobotomy Posted November 30, 2005 Share Posted November 30, 2005 Geo said: do you think thats what its doing then "knocking"is that the same as detonating?Knocking/detonation are two names for the same thing. However it isn't the same sound as you're getting I don't think. Detonation sounds like an electrical crackling type noise.It could be that the ECU is picking up on slight knock (because of the 95RON) and retarding the ignition. But that wouldn't sound like it's running on 3 cylinders, it would just feel like a lack of power.More likely that it's your plugs, leads or distributer. Try spraying some WD40 into the ends of the leads to displace any dampness. Also try cleaning the distributer arm/contacts. It could also be running your tank near empty has picked up some crap from the bottom of the tank and clogged the fuel filter (but I think that's more unlikely)If your car isn't getting up to temp (due to your knackered thermostat) then what'll be happening is that the radiator is constantly cooling the engine. You should watch with this as the ECU may be running on cold start and firing in extra fuel which could be causing borewash. Quote Link to post Share on other sites
baz14062003 Posted November 30, 2005 Share Posted November 30, 2005 mine was doing same other week bak but worse mate,was my plugs that were buggerd,a quick change over solved the problem 4 me mate Quote Link to post Share on other sites
SiCaln Posted November 30, 2005 Share Posted November 30, 2005 Where can u get them remapped for 95 ron petrol mate? Quote Link to post Share on other sites
lobotomy Posted November 30, 2005 Share Posted November 30, 2005 You'd need an aftermarket ECU (standalone) or a chip (like Dastek say - although I've heard mixed things about their chips.) To run 95RON Quote Link to post Share on other sites
Guest Enzo Posted November 30, 2005 Share Posted November 30, 2005 ie checked the plugs and the leads,seams that there is white scoring on them so ill be after a new set,but when speaking about plugs, which ones are the best, and what heat range do i go for? Quote Link to post Share on other sites
Simon Posted November 30, 2005 Share Posted November 30, 2005 Just contact Daveburwash at starletgtturbo.co.uk he'll sort you out with a set at a good price.Simon Quote Link to post Share on other sites
Guest Enzo Posted November 30, 2005 Share Posted November 30, 2005 thanx Sy Quote Link to post Share on other sites
Guest Enzo Posted November 30, 2005 Share Posted November 30, 2005 ill do that Jay, thanx for all the input guys Quote Link to post Share on other sites
gaz Posted December 1, 2005 Share Posted December 1, 2005 i had it in my escort, horrible feeling, was the wet! and crap in the engine, it wasnt getting driven much. put some redex in or wahtever. Quote Link to post Share on other sites
DAN_GTT Posted December 3, 2005 Share Posted December 3, 2005 detox is very good stuff, cleans the fuel system and injectors etc, i would put some of that in aswell once you done plugs Quote Link to post Share on other sites
Guest Enzo Posted December 3, 2005 Share Posted December 3, 2005 first thing i did when i got up home was a minor service chnaging the oil filter(total cunt to do) and fresh new oil Quote Link to post Share on other sites
glenn Posted December 3, 2005 Share Posted December 3, 2005 yes i know mate i couldnt even find my filter what a stupid place to put it Quote Link to post Share on other sites
Robbo Posted December 4, 2005 Share Posted December 4, 2005 go for heat range 8 spark plugs.always use optimax! standard fuel in japan is 100ron, dont know what their high performance fuel is, if your car was run on high performance fuel there (could be 103ron or something) then a drop to 95 wouldn't be the best thing to do. should ideally carry a bottle of octane booster for emergencies like that, but it should be fine once you get it out of the tank and to the good stuff. Quote Link to post Share on other sites
trip Posted December 8, 2005 Share Posted December 8, 2005 I don't recon it's knocking, pinging or none of the sort, cause I run 11PSI and spool quick as fuck on my shit gas here and don't experience any of those things :S I believe it may be the Plugs or PLug leads, altern if you notice putting in different gas helps , could also be your fuel filter. Quote Link to post Share on other sites
Guest Enzo Posted December 8, 2005 Share Posted December 8, 2005 ive checked the plugs and leads,fual filer also looks brand new tooi serviced her just after i got italways put super in it then this one tie i put shitty fual in and tryed to rag the tits off it,thats when it started to happenso only super nowits all but gona away now so i dont know what it was,didnt sound healthy though Quote Link to post Share on other sites
