Fitted my new dgr coilovers last night, wound the fronts three quarters inand they sat nice... adjusted the rears the same and they sat high so I fully adjusted them to the max and this is how they sit
924D7A91-CFA3-42E6-AB1B-D9E548FE1C03-154
  • Replies 70
  • Created
  • Last Reply
Top Posters In This Topic
arent CJ doing a gb on these? may be worth speaking to them to see if they can offer any advice - ie make sure youve got the correct parts etc as opposed to it being a manufacturer/design flaw
Lol! Cheers mate James and jarrod have told me I can lower the spring on the shock to lower it more, ill take some pics as I'm doing it and let you know the results :)
Don't forget to keep damper as hard as it goes then drive it and sofen accordingly and put all 4 to the hardest then count the clicks so u match fronts to eachother then match back to what ever you decided is good for you
I thought that, basically I've been told to set damping as hard as it will go then loosen the spring so it's slack and lower the jack so the damper takes the slack off the spring then after half an hour soften the damping until I'm happy with height (they have damping adjusters on the top)
Nice one Jarrod
wouldnt have thought adjusting the damping would effect height adjustment, so are you changing the preload? ^
also the rears will need to be softer than the fronts as the rears have more spring weight, be interesting to see how they compare to meisters on uk roads
the knob you turn at the top affects damping not ride height, none of the sets of coilovers i purchased/fitted have said anything about messing with the damping adjustment to obtain correct ride height....as for the riding around on hard.....RIP spine...adjust to 10 clicks from the softest for the front and 5-6 on the back and see how you like it....
as for the pre-load (how compressed the spring is) it should be so the spring is snug and doesnt move freely AND isnt under any great tension.....you should be able to pretty much bottom out i.e have no arch gap without even touching the springs pre-load
in my experience of course...
That's what I've always thought and I checked the instructions last night and they said the only way to adjust ride height is by loosening the bottom locking ring and winding the bottom mount further up the threaded tube which I've done as much as possible, if the threaded tube was shorter it would solve my problem but I'm not about to drop £500 on a set of coilovers and then start hacking them up... I hope that's not the lowest they go at the rear.
You are adjusting it correctly. Do not loosen the locking ring that holds the springs in place, yes your car will go lower but it's not the right way to adjust them and as Asad said, the spring should not be loose.
That's completely wrong, and your instructions make that clear!
They've made the threaded part that goes not into the base of the coilover too long by the looks of things. Would handle awesome like that to. Get them sent back!
