RossTRD Posted February 28, 2013 Posted February 28, 2013 With 15" wheels whats the biggest caliper and disc size? Quote
smobey_sutton2 Posted February 28, 2013 Posted February 28, 2013 Probably worth stating your make and model of wheel also mate, as it varies depending on the wheel. Quote
Keri-WMS Posted February 28, 2013 Posted February 28, 2013 Normally 275-280mm in 15's, and 295-300mm in 16's - applies to nearly all wheels. There are the odd makes like Compomotive or Team Dynamics where they leave a bit more room and you can sometimes get 300mm inside a 15" for instance...or deeper (rear wheel drive) offset ones like TVR use where our 15" kit is a 300mm one. Quote
RossTRD Posted February 28, 2013 Author Posted February 28, 2013 They're wolfrace alloys shown in my pic? Quote
Liam_D Posted March 1, 2013 Posted March 1, 2013 I have 275mm under my 15'' Slipstreams and there's a few MMs of room still. Quote
jakeep82 Posted March 17, 2013 Posted March 17, 2013 imo dont skimp with your brakes dont try and get the cheaper option from another car whats been converted to fit , feel so much more comfortable with a big 4 pot set up , get your self over to keri at wms may seem a lot for "just a set of brakes" but there worth every penny !! nothing better then having the feeling of knowing you can stop if need be ;) Quote
Starbuck Posted March 17, 2013 Posted March 17, 2013 A lot of peeps run the 'other cars' brake option and they're fine. Depends on your funds. Quote
Amjad Posted March 17, 2013 Posted March 17, 2013 On 3/17/2013 at 9:45 AM, Starbuck said: A lot of peeps run the 'other cars' brake option and they're fine. Depends on your funds. x2 You don't need to spend a stupid amount. As much as everyone would like off the shelf upgrades, there a lot of other options out there for a lot less money Quote
AlancEP82 Posted March 17, 2013 Posted March 17, 2013 On 3/17/2013 at 12:28 PM, Amjad said: x2 You don't need to spend a stupid amount. As much as everyone would like off the shelf upgrades, there a lot of other options out there for a lot less money x3 il be going for levin twin pots,think they will be up to the job,as many lads use them,cheap upgrade to Quote
jakeep82 Posted March 17, 2013 Posted March 17, 2013 definately a cheap upgrade , im just a fanny and worry about too many things going wrong lol like starbuck says depends on your funds Quote
AlancEP82 Posted March 17, 2013 Posted March 17, 2013 (edited) or get evo 8 bremos,and get disc to suit and get custom made carriers Edited March 17, 2013 by AlancEP82 Quote
rmsnoel Posted March 17, 2013 Posted March 17, 2013 You dont want brakes better than your tyres either. Ill be going for normal singlepot uk corolla brakes. 255mm but 22mm thick discs Quote
Jamie1st Posted March 17, 2013 Posted March 17, 2013 (edited) Ive got Ksport 6 pots 286mm? I've got fortran ssv wheels (JDM) and there is 1mm max gap between caliper, and wheels., people say they're an overkill, but I think they are one of the best things I've bought. 130mph into a corner at Donnington wasn't fun when I had NO brakes (cooked/cracked standard), now with the 6 pots they dont have any change in feel, or cook after a full track day! If you're going to track it, spend the money on decent stuff, if its a fast road car/street, standard are ususally ok if all working right, decent discs and decent pads. Edited March 17, 2013 by Jamie1st Quote
AdamB Posted March 18, 2013 Posted March 18, 2013 On 3/17/2013 at 3:22 PM, AlancEP82 said: or get evo 8 bremos,and get disc to suit and get custom made carriers That won't be possible because there would be no pad touching the disc as the disc would be too small. Calipers are designed to work within a certain range of disc sizes. On 3/17/2013 at 4:43 PM, rmsnoel said: You dont want brakes better than your tyres either. Exactly this, if the tyres lock up then your overpowering the force the tyres can produce. Quote
Jamie1st Posted March 18, 2013 Posted March 18, 2013 On 3/18/2013 at 12:53 PM, AdamB said: That won't be possible because there would be no pad touching the disc as the disc would be too small. Calipers are designed to work within a certain range of disc sizes. Exactly this, if the tyres lock up then your overpowering the force the tyres can produce. This is true, how ever it wasn't the stopping power that I found real poor on the Glanza's, its there ability to disperse heat. Its the reliability you get with bigger brakes, knowing they wont fade coming into a corner at 100+. I could lock the wheels up with standard brakes (ABS fuse romoved, as starlets abs is too sensitive), but that doesnt mean the brakes are good enough. Will they still do that after a 15/20min session? The Kpsorts I can lock the front wheels up at 130mph quite easily, but when do you ever use 100% of the braking force? All about control and getting used to them. Ive not met anyone yet saying that there brakes are too good. Quote
Jamie1st Posted March 18, 2013 Posted March 18, 2013 (edited) On 3/18/2013 at 12:53 PM, AdamB said: That won't be possible because there would be no pad touching the disc as the disc would be too small. Calipers are designed to work within a certain range of disc sizes. Exactly this, if the tyres lock up then your overpowering the force the tyres can produce. Also, you just have the discs machined to fit your hubs (Evo 8 ) you wouldnt use standard discs as they're as thick as some a4 paper lol Edited March 18, 2013 by Jamie1st Quote
