kbond Posted March 4, 2013 Posted March 4, 2013 (edited) To cut a long story short the ringlands went on my engine again so i bought another standard engine which i had been told was 100% working with good compression, only thing was he had started taking the head off as was going to forge it but bought another engine anyway i recieved the engine on friday and thought i would just use the bottom end and use my head as i only had it skimmed ect a few months ago. Built all the engine up with new head gasket and put it in the car got everything bolted on started it up... And there is smoke pouring out of the exhaust and in the 5 minutes it was running i checked the oil cap which was creamy and the dipstick which looked like it had water mixed with oil on. Now i no the head is working perfect. You cant really get any pipes mixed up as there arent any external oil pipes apart from the turbo. Only thing i can think of is either head gasket on wrong, which i am sure it was on right as i checked it 10 time lol, or the block which was supposed to be 100% has a crack in???The smoke coming out of the exhaust doesnt smell like oil at all i am sure it water as its loosing loads of waterWhat do people think?Have been through nothing but problems with this car since i bought it so may be up for sale soon! Either that or crush it and put it on my mantal piece! Edited March 4, 2013 by kbond Quote
kbond Posted March 4, 2013 Author Posted March 4, 2013 Well the head has had new valve stem seals valves have been reground and been skimmed and im sure i put it on the right way as i chech it 10 times!Will be taking the head off again tomorrow to see if it is Quote
Beastmode panda Posted March 4, 2013 Posted March 4, 2013 Water mixed with oil which creates the 'mayo' stuff - headgasket. Quote
kbond Posted March 4, 2013 Author Posted March 4, 2013 The head was previously on my other engine for a few months until the ringlands went but was running spot on then Quote
kbond Posted March 4, 2013 Author Posted March 4, 2013 Will be taking the head off again tomorrow to investivate AGAIN!I do hope i put it on wrong though and it isnt a cracked block or anything Quote
Jamie_VF22 Posted March 4, 2013 Posted March 4, 2013 you did plumb it in correctly didnt you mate , option 2 could be you put a water hose on a vac line on the inlet manifold just a maybe worth a check alot of people have done it Quote
kbond Posted March 5, 2013 Author Posted March 5, 2013 Has anyone got a little guide to show which pipes go where on the inlet? Quote
melon Posted March 5, 2013 Posted March 5, 2013 Just don't twist them and it should be fine. Also the possibility that you've scratched the head? Easy to catch the surface on the dowels in the block when you put it on Quote
H_D Posted March 5, 2013 Posted March 5, 2013 This will tell you where to plumb the throttle body pipes. http://www.toyotagtturbo.com/forums/showthread.php?67023-Throttle-Body-Pipes-* Quote
kbond Posted March 5, 2013 Author Posted March 5, 2013 This will tell you where to plumb the throttle body pipes.http://www.toyotagtturbo.com/forums/showthread.php?67023-Throttle-Body-Pipes-*Thanks for that mateSo what lines should be connected to the pipe that runs along the back of the inlet? Quote
H_D Posted March 5, 2013 Posted March 5, 2013 do you mean the metal pipe which connects to the waterpump? Quote
kbond Posted March 5, 2013 Author Posted March 5, 2013 No the small pipe that is bolted to the back of the inlet? as i think i have a pipe coming from the water pump pipe to this one Quote
kbond Posted March 5, 2013 Author Posted March 5, 2013 All sorted now guys thanks for all your helpHad the pipes on wrong on the throttle body and inlet, feel like a twat now lol Quote
Jamie_VF22 Posted March 5, 2013 Posted March 5, 2013 thought is was after thinking abit more about it glad its all sorted buddy Quote
AdamB Posted March 6, 2013 Posted March 6, 2013 Not the first one to do it mate, and certainly won't be the last! Glad you got it sorted Quote
Crooks Posted September 9, 2013 Posted September 9, 2013 How did u mange to get the water outa the pistons ? Quote
dangeestarlet Posted September 9, 2013 Posted September 9, 2013 Done that on my old red starlet when I put a rolla inlet on, had to change the oil and give it a good thrashing to clear the smoke, had me rubbing my head for a few hours wondering why it wouldn't start lol Quote
