russ78 Posted March 5, 2013 Posted March 5, 2013 May sound like a gay question but how do people attach the reg plate when its offset i could use self tappers but they will rust and won't tape just fall off ? Quote
Matts Posted March 5, 2013 Posted March 5, 2013 (edited) Im sure it's like a number plate tilt you can buy them ill find oneHere from tegiwa but expensive just make onehttp://bit.ly/13EMBkC Edited March 5, 2013 by Matts Quote
Matts Posted March 5, 2013 Posted March 5, 2013 (edited) If that is what you mean that is Edited March 5, 2013 by Matts Quote
daniel_g Posted March 5, 2013 Posted March 5, 2013 Two little L shaped brackets from B&Q work well. Quote
russ78 Posted March 5, 2013 Author Posted March 5, 2013 If that is what you mean that isI mean offset from the centre of the bumper but i guess this could work yeah Quote
russ78 Posted March 5, 2013 Author Posted March 5, 2013 Two little L shaped brackets from B&Q work well.how would l shaped brackets work ? Wouldn't they need to be U shaped Quote
Matt1878 Posted March 5, 2013 Posted March 5, 2013 L shape mate.. Not I shape.Two L shape brackets either side and then screw the plate to it.. Sure I've heard some people just using Velcro!? Quote
daniel_g Posted March 5, 2013 Posted March 5, 2013 Nah russ, L shaped ones work if you screw one hole to the back of the plate obviously, and the other bit of the bracket to a part of the bumper that faces up the way, if yo get what i mean. Also when you remove it you wont see any holes in the front of the bumper because you make the holes up the way. Tbh, plate tape nowadays is fucking solid, and more than capable if you use the decent stuff. Quote
russ78 Posted March 5, 2013 Author Posted March 5, 2013 I see how this bracket works now much better as its out of sight exactly what im looking for had issues a few times with reg plate tape coming lose and have no faith in it anymore Quote
Amjad Posted March 5, 2013 Posted March 5, 2013 Velcro tape is really good, just clean the surface thoroughly and apply it well Quote
Liam_D Posted March 6, 2013 Posted March 6, 2013 Tegiwa numberplate re-locator kit and then cable tied to that! Not the best looking or that stable but stops the police pulling me over! Quote
