can any one find a UK seller for m12x1.25 banjo bolt
The actual banjo just needs to be an M12 - the thread doesn't matter (there is no thread on the banjo just a through hole). So the one you linked would be fine but you just need a different banjo bolt.
Edited by WallaceGlanza
The race tech lines come with the banjo's fitted to hose so it's just the bolts you need..... http://www.race-tech.net/index.php?main_page=product_info&cPath=2_6&products_id=35
I could make this simple for you by flogging you the 2 water line banjo bolts and one oil line banjo bolt (plus copper washers) as I have the lot here. :p
Or http://www.ebay.co.uk/itm/M10-x-1-5-Banjo-Bolts-With-2-Washer-For-Car-Motorcyles-/280568650948?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item415331dcc4
Plus
http://www.ebay.co.uk/itm/M12-BANJO-BOLTS-FOR-12MM-BRAKE-LINE-MOTORCYCLE-BANJO-BOLT-COPPER-WASHERS-/280744800162?pt=UK_SportingGoods_OtherSports&var=&hash=item415db1afa2
Same seller, 8 quid, sorted.
