*Andrew*H* Posted March 8, 2013 Share Posted March 8, 2013 Hi all bought a V wid a blown engine took the head off 2 see what damage had been done and found the pistons were fine with no play in bottem bearings and all valves seem 2 be fine. Tried turning engine over by hand 2 c if it had seized and it turned over fine. All bores were fine 2 anyone have a clue as what it coukd of been Quote Link to post Share on other sites
Jhandy Posted March 8, 2013 Share Posted March 8, 2013 check to see if its spun a bearing if it has it can show no shaft play because the bearing would have wedged itself in there good Quote Link to post Share on other sites
rmsnoel Posted March 8, 2013 Share Posted March 8, 2013 Cracked ringlands on the side of pistons, turbo seals or valve stem oil seals. Whats it doin?Burning oilKnockingPowerlossWont startAny damage to the headgasket? Quote Link to post Share on other sites
*Andrew*H* Posted March 8, 2013 Author Share Posted March 8, 2013 dont no what it done mate bought it blown mate with the intention of goin forged. There was hardly any oil in the sump. None on dip stick Quote Link to post Share on other sites
rmsnoel Posted March 8, 2013 Share Posted March 8, 2013 Did u have it running or anything? Quote Link to post Share on other sites
*Andrew*H* Posted March 8, 2013 Author Share Posted March 8, 2013 I havent mate i trailored it bk and just striped the whole car down 4 spares. The bloke said it just lost power and all the dials went dim and wouldnt start again. Im confused lol Quote Link to post Share on other sites
morgey Posted March 8, 2013 Share Posted March 8, 2013 Bad earth or power supply? Lol Quote Link to post Share on other sites
aaddzz123 Posted March 8, 2013 Share Posted March 8, 2013 Power fading out and not starting again sounds as simple as an alternator lol..... Did you not try topping the oil up and starting it before stripping it down? If the engine has blown due to no oil, chances are it's spun a bearing as said above and locked the engine... But if it turns over fine I'd take the caps off the rods and double check the bearings, double check the bores, tap the pistons on a hard surface to see if any chunks fall out or the rings break etc. If all is fine, face palm yourself, put it back together with a new gasket/seal kit and try it lol! Might be fine . Quote Link to post Share on other sites
*Andrew*H* Posted March 8, 2013 Author Share Posted March 8, 2013 Na i didnt try start it because the lad i bought it if said it had done a piston and was fucked lol i think il av 2 get sm1 with more experienced have a look at it. If it is fine what ya think carry on with the forged plan? Or sell it on make a bit of money and buy a fucked engine 2 forge as it only owses me 200 quid lol Thanks 4 the advise as well Quote Link to post Share on other sites
aaddzz123 Posted March 8, 2013 Share Posted March 8, 2013 Haha!! Should have tried it dude! No harm if it's already fucked and to be honest a lot of people don't have a clue and just assume "oh must be fucked!" if it stops and doesn't start straight away .... If you're unsure, get it checked by a professional. If it's fine, it's already in bits and if it only cost you £200 I'd just stick with that and forge it... After you've rebuilt it with new gaskets you're probably not going to make much on it... Be a different story if it were still whole and running sweet . Quote Link to post Share on other sites
*Andrew*H* Posted March 8, 2013 Author Share Posted March 8, 2013 Hum think i shoulda spoke 2 people on here before just diving in doin wat i think lol Quote Link to post Share on other sites
rmsnoel Posted March 9, 2013 Share Posted March 9, 2013 Andrew I think you just.murdered a glanza lol Quote Link to post Share on other sites
daniel_g Posted March 9, 2013 Share Posted March 9, 2013 Pick up a second hand FTE, drop it in, get it up and running then forge the other one in the meantime. Sorted. Quote Link to post Share on other sites
*Andrew*H* Posted March 10, 2013 Author Share Posted March 10, 2013 I have 1 that is up and running this engine came out of another 1 i bought 4 spares Quote Link to post Share on other sites
Gav_kara Posted March 10, 2013 Share Posted March 10, 2013 I'd of fired it up to diagnose the problem before ripping apart some general checks and turn the key if its knocking its arse off or down a pot then strip. Quote Link to post Share on other sites
