I've seen some merc and bmw exhaust use phneumatic actuators to open a second tip of an exhaust up. could make one easy enough just use an old turbo actuator. works in the same way, stays shut under vac then opens on boost
so an external wastegate then?
No, what Maddox is on about is fitted in the back box is believe i have seen it too on the higher specced BMWs. Unsure how much it'll actually work though.
I've got a front exit with a nice bracket made up, not going to use it tho.
Think the s14's had a flap in the exhaust to make it a bit quieter to, I remember putting a hks system on one and it came with a spacer to remove it.
Don't think u would see a massive gain mate bar from reduced lag and maybe an increase in torque
I am also pretty tempted to get a front exit once the td04s done! Unsure if i could give up the BC Spec 2 though!
U will never get rid of that exhaust lol and u know it :)
