Matt1878 Posted April 15, 2013 Posted April 15, 2013 Need some help chaps... My dad decided to stab a screwdriver through my rad and now it's pissing coolant lol. Tried to seal it and its having none of it lol.. Need something cheap, really cheap as I'mSKINT!! Cheers in advance,Matt
TrisK Posted April 15, 2013 Posted April 15, 2013 Need some help chaps... My dad decided to stab a screwdriver through my rad and now it's pissing coolant what a bastard, surely he should be paying
Matt1878 Posted April 15, 2013 Author Posted April 15, 2013 what a bastard, surely he should be paying Oh he will be don't you worry!! Lmao..
Weyro Posted April 15, 2013 Posted April 15, 2013 You can get civic half rads on ebay for £25 delivered, http://www.ebay.co.uk/itm/HONDA-CIVIC-1991-2001-CR-X-HR-V-MANUAL-RADIATOR-BRAND-NEW-2-YEAR-WARRANTY-/271163787958?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Model%3ACivic&hash=item3f229f0ab6
Matt1878 Posted April 15, 2013 Author Posted April 15, 2013 You can get civic half rads on ebay for £25 delivered, http://www.ebay.co.uk/itm/HONDA-CIVIC-1991-2001-CR-X-HR-V-MANUAL-RADIATOR-BRAND-NEW-2-YEAR-WARRANTY-/271163787958?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Model%3ACivic&hash=item3f229f0ab6I need something that's just going to bolt on though ... I need a fan and mounting kit too :/
ryan lang Posted April 15, 2013 Posted April 15, 2013 you wont get a half size that will bolt on dude make a fitting kit i used my old top rad brackets and a piece of metal with 2 holes, one bolted to the bar and the other over a lug in rad go to a breakers and rob a rad and fan and just wire it up. easy enough, blue wire to blue wire, black wire to black wire ;) ill take pics of mine now for you
pacman Posted April 15, 2013 Posted April 15, 2013 Selling a half sized alloy one here:http://www.ukstarletowners.com/topic/64121-benefit-from-some-breakage-assess-the-assets-on-offer/#entry822474
Matt1878 Posted April 15, 2013 Author Posted April 15, 2013 Selling a half sized alloy one here:http://www.ukstarletowners.com/topic/64121-benefit-from-some-breakage-assess-the-assets-on-offer/#entry822474Seen that dude.. Need something cheaper though
Socks Posted April 15, 2013 Posted April 15, 2013 go to a scrappy and gt a rad out of an NA starlet for £10 if u need a quick fix.. Save up and buy a alloy core civic radiator and mounting kit with fan!
TrisK Posted April 15, 2013 Posted April 15, 2013 you wont get a half size that will bolt on dude make a fitting kit i used my old top rad brackets and a piece of metal with 2 holes, one bolted to the bar and the other over a lug in rad go to a breakers and rob a rad and fan and just wire it up. easy enough, blue wire to blue wire, black wire to black wire ;) ill take pics of mine now for youHes lying to you like the welsh do Matt. it will bolt on using a civic top rad bracket, the standard lower bracket. then your only dilema is a fan which you can use your aircon fan if you have that kicking about
Matt1878 Posted April 15, 2013 Author Posted April 15, 2013 Hes lying to you like the welsh do Matt.it will bolt on using a civic top rad bracket, the standard lower bracket. then your only dilema is a fanwhich you can use your aircon fan if you have that kicking about Don't have that fan :/ got rid of the whole unit a while back
ryan lang Posted April 15, 2013 Posted April 15, 2013 all i did with the bottom mounts (standard top brackets) was cut the rubber out and drill a hole the same size as the lugs on the bottom of the rad, then drill smaller holes in the lip to bolt them to the car. you've also got to remove the standard bottom mount other wise the rad will sit to high trisk. the civic rads are taller than the standard rad and will sit off to one side of the civic rad leaving it unstable and on a wonk also you cant see the bottom bracket on the other side, but its the same height, and same thing other side on the bottom of the rad
Hawwy Posted April 15, 2013 Posted April 15, 2013 I have one with fans hoses and a bracket £30 to your door
TrisK Posted April 15, 2013 Posted April 15, 2013 Not true RyanStandard bottom mount, and oem civic top bracketLeaves it sitting like this:Not massively high, or wonky imo
ryan lang Posted April 15, 2013 Posted April 15, 2013 not too bad. id still prefer 2 bottom brackets instead of resting across one
