PaulStarletSR Posted May 16, 2013 Share Posted May 16, 2013 as above i need the vac lines for these 2 mystery pipes! any info would be great! Quote Link to post Share on other sites
TurboTobz Posted May 16, 2013 Share Posted May 16, 2013 Struggling to understand what your after, if it's the two pipes on inlet left hand goes to map sensor right hand one on mine is blocked, can't remember exactley why I blocked it. Lol hope thats some form of help Quote Link to post Share on other sites
StuDoc 72 Posted May 16, 2013 Share Posted May 16, 2013 Think he wants to know where the 2 on the steering rack go buddy. Im assuming 1 will go to the inlet mani paul. Can you no check where daves go? Quote Link to post Share on other sites
PaulStarletSR Posted May 16, 2013 Author Share Posted May 16, 2013 daves workin and wont b able to see his til weekend and am hittin this fuckin prick of an SR hard yesterday,today, saturday n sunday. wana get some real progress made. any idea which 1 goes to the inlet and where? Quote Link to post Share on other sites
Socks Posted May 16, 2013 Share Posted May 16, 2013 The ones on the rack idle up the engine when the PAS pump becomes under load... I just U'd off the ports with a piece of vaccum line... make sure u blank the inlet off ports tho! Quote Link to post Share on other sites
PaulStarletSR Posted May 16, 2013 Author Share Posted May 16, 2013 The ones on the rack idle up the engine when the PAS pump becomes under load... I just U'd off the ports with a piece of vaccum line... make sure u blank the inlet off ports tho! well I've found these vac lines hangin off my inlet and the thing next to the coil pack and theres no other place for these vacs to go so im guessin now.....the inlet 1 would go on the left pipe would it?? Quote Link to post Share on other sites
PaulStarletSR Posted May 16, 2013 Author Share Posted May 16, 2013 bump Quote Link to post Share on other sites
daniel_g Posted May 16, 2013 Share Posted May 16, 2013 Right man, the port on the rack nearest the drivers side goes to a port on the vacuum rail, which sits/bolts under the inlet mani. The other port runs to a port on the throttle body, the vac port which is nearest the bulk head. Or alternatively just loop the two ports on the rack, and loop the two between the TB and the vac rail. Quote Link to post Share on other sites
PaulStarletSR Posted May 16, 2013 Author Share Posted May 16, 2013 so wtf do i do with the 2 am holdin in the pic?lol Quote Link to post Share on other sites
daniel_g Posted May 16, 2013 Share Posted May 16, 2013 Where do the ones youre holding go to? Quote Link to post Share on other sites
Lew91 Posted May 16, 2013 Share Posted May 16, 2013 The ones on the rack idle up the engine when the PAS pump becomes under load... I just U'd off the ports with a piece of vaccum line... make sure u blank the inlet off ports tho!Just to double check mate I can loop the 2 on the rack itself? I'm doing a PAS delete and not sure what to do with the vac lines. PS: not meaning to hijack the thread. Quote Link to post Share on other sites
daniel_g Posted May 16, 2013 Share Posted May 16, 2013 Yes lew you can do that. Loop the ones on the rack, and the one on the vac rail to the TB aswell. Quote Link to post Share on other sites
Lew91 Posted May 16, 2013 Share Posted May 16, 2013 Ah nice one cheers mate, saves faffing around Quote Link to post Share on other sites
daniel_g Posted May 16, 2013 Share Posted May 16, 2013 Did you get hold of a non PAS rack, column etc. ? Quote Link to post Share on other sites
PaulStarletSR Posted May 16, 2013 Author Share Posted May 16, 2013 Where do the ones youre holding go to? 1 goes to a wee vac on the inlet and the other 1 goes down to a wee box thing next to the coilpack mate Quote Link to post Share on other sites
Lew91 Posted May 16, 2013 Share Posted May 16, 2013 If its on the sr that little black box is basically nothing lol. It should have another line going to the charcoal canister. Quote Link to post Share on other sites
daniel_g Posted May 16, 2013 Share Posted May 16, 2013 If you have this still attached to the coilpack ignitor then get it in the fucking bin and block off the top TB ports. Just causes hassle and random vac lines everywhere.And the carbon canister that lew mentioned.This is the best pic i have atm of the vac pipes youre talking about. Quote Link to post Share on other sites
Lew91 Posted May 16, 2013 Share Posted May 16, 2013 (edited) He might not have them dan as there all air con crap. That's a handy pic of the rack vac lines tho. If it was me I'd remove the little black box along with charcoal canister but be sure to put a one way valve thingy on.Edit: isn't that other pipe something to do with the hi/lo boost solenoid? Edited May 16, 2013 by Lew91 Quote Link to post Share on other sites
daveEP Posted May 16, 2013 Share Posted May 16, 2013 Paul av got the pipes for your power steerin and know where they go so dont worry about that lol. Quote Link to post Share on other sites
daniel_g Posted May 16, 2013 Share Posted May 16, 2013 Yeah Lew ano, wasnt sure if he got all that shit still attached to the ignitor when he got it ? And defo get rid of the carbon canister shit too. That line may well have something to do with the hi/low solenoid. I had a few wee random solenoids but didnt fit them lol. You'll get there Paul mate Quote Link to post Share on other sites
PaulStarletSR Posted May 16, 2013 Author Share Posted May 16, 2013 cheers dave! cheers for the help boys Quote Link to post Share on other sites
Frankieflowers Posted July 23, 2021 Share Posted July 23, 2021 (edited) On 5/16/2013 at 11:43 PM, daniel_g said: If you have this still attached to the coilpack ignitor then get it in the fucking bin and block off the top TB ports. Just causes hassle and random vac lines everywhere. http://i1149.photobucket.com/albums/o585/daniel_gg/20130324_153420_zps3bd4293c.jpg And the carbon canister that lew mentioned. This is the best pic i have atm of the vac pipes youre talking about. http://i1149.photobucket.com/albums/o585/daniel_gg/20130318_201038_zps72e5be8e.jpg Anyone still here? I’m having trouble with a few hoses. Swapped the engine in a Corolla. I don’t want to leave anything hanging. The two pipes I have a loose are apparently one for water and one for air. One of those plastic spirals is holding them together. @Jay send me a picture of the throttle. Number two is next to another hose which isn’t on the throttle but on the inlet right next to it I need to know how to connect them and where. Thanks Edited July 23, 2021 by Frankieflowers Quote Link to post Share on other sites
