Dean ep82 Posted May 17, 2013 Posted May 17, 2013 Can anyone point me in the right direction for what cable I need to relocate my battery in the car.Thanks dean Quote
JayJ Posted May 17, 2013 Posted May 17, 2013 If you are going to relocate it in the boot it would be good to use 50-75mm2 cable for the safety. Remember to add a fuse near the battery in case the cable peels off for some reason then you won't burn the whole car. Quote
Panda.gt Posted May 17, 2013 Posted May 17, 2013 if youve got the patience go to a breakers find a bmw that has the battery in the boot and rip it out! takes a while but it is posible Quote
steviet Posted May 17, 2013 Posted May 17, 2013 If you are going to relocate it in the boot it would be good to use 50-75mm2 cable for the safety. Remember to add a fuse near the battery in case the cable peels off for some reason then you won't burn the whole car. Thinking about doing this sometime soon, what do you mean in regards to adding a fuse near battery ? Stevie Quote
JayJ Posted May 17, 2013 Posted May 17, 2013 (edited) Thinking about doing this sometime soon, what do you mean in regards to adding a fuse near battery ? Stevie If you have a fuse near the battery(in a boot) and the cable gets shortcircuited the fuse will burn. If you don't have a fuse (or have it in an engine bay) and the cable gets shortcircuited there's is nothing to stop the current. If you use too thin cable you'll get voltage drop as the cable works like a resistor in this case and could overheat too. Edited May 17, 2013 by JayJ Quote
Dean ep82 Posted May 17, 2013 Author Posted May 17, 2013 If you are going to relocate it in the boot it would be good to use 50-75mm2 cable for the safety. Remember to add a fuse near the battery in case the cable peels off for some reason then you won't burn the whole car. Thanks Quote
Rob H@RCH Engineering Posted May 17, 2013 Posted May 17, 2013 As Jay said is always best to use a fuse the closer to the battery the better this is where I put mine its the black box on the front of the battery box. http://s87.photobucket.com/user/turbosr_2006/media/toylet/null_zps78b8c6c3.jpg.html'> Quote
steviet Posted May 17, 2013 Posted May 17, 2013 So meaning that I run my live wire from engine loom to a mega fuse (within a fuse holder) at the battery, and run the live wire off the battery post to the fuse holder ?? What amp of fuse should I use ??Is 322/0.30 170amp cable ok ?? Cheers Stevie Quote
JayJ Posted May 17, 2013 Posted May 17, 2013 640/0.30mm might be better. Do it like this: [battery+]----[fuse]----------[engine bay] connect this end to where your current battery post connects at the moment[battery-]-----[earth] connect this end to car's shell in a boot Clear? Quote
daniel_g Posted May 17, 2013 Posted May 17, 2013 I'll be doing this soon too. Any links where to buy the correct stuff ? Quote
JayJ Posted May 18, 2013 Posted May 18, 2013 (edited) Car audio stores could be the right place to find the cables and connectors. You can also replace the fuse with an automatic circuit breaker, so you don't have to have a spare fuse at all.Usually boat shops sell those and they look like this Check your current main fuse rating and go with the same rating for a circuit breaker. Don't take too low rated as the starter motor can take a lot of current. I think 100A or 150A would be enough though Edited May 18, 2013 by JayJ Quote
