Went to fit my wideband today but if i take the sensor 36 inches away from the turbo(as per instructions) it would be in the middle of the back box!
Surley i cant have it in the box?
Any ideas?
Guidelines...
Id just pop it in the pipe a few inches from the backbox if it was me... Cant effect readings that much surely....
You havent got much other choice either...
Thats what i was thinking adam. Id have popped it right in at the tail pipe but its gonna be a toght squeeze behind the front bumper i dont want the sensor on the outside of the bumper for obvious reasons lol
You could drill a hole in the tip and fit it in there, but problem is with that like you say is the bumper. If you can angle the sensor you may get away with it if the tip doesn't stick too far out.
my wideband sensor probe(followed the instructions) said to to put it x amount from turbo,it ended up just under gearbox.
middle box on is not right.
Surely in the tip it would be inaccurate? I'd put it before the box IMO
Why would it be inaccurate? How do you think tuners use their widebands? They shove the probe up the tailpipe.
Tbh providing its not going to be providing a signal to an aftermarket ecu like a standalone then I wouldn't really worry too much where it goes, but where ever it does go it may shorten the lifespan of the sensor.
Fair point, but are tuners widebands designed to be at the rear? I'm only thinking theoretically hence the question mark, but the way I see it it's not only measuring what's in the exhaust but atmosphere too? I'm probably wrong, I know you know what your on about don't take that the wrong way.
Mm true, although I would expect the exhaust gas to be exiting the pipe to be of a greater pressure than atmosphere. I think the exhaust is so short anyway it will be a problem no matter where it goes lol.
I would possibly shove it in before the back box but actually in it with the sensor pointing down slightly.
  • 9 months later...
Going to get this welded in before the back box, will it affect the readings or just the life of the sensor? Dont mind if i have to change the sensor after a while but dont want to have dodgy reading! Haha
It wont shorten the life span that much and the replacement wideband sensors arent that expensive, its the name, controller and gauge you pay for. The sensors themselves are just Bosch units.
Lifespan of sensor due to exhaust gas temps doubt you'll notice much difference as your not overly close the the heat source.
The bosch sensor makes up 50-60% of the costs of most kits they're not exactly cheap but I really doubt you'll see much difference in lifespan
