DamoC Posted May 26, 2013 Posted May 26, 2013 Hi guys and girls!Just a quick question... My car will idle fine from cold! Will idle about 1k, till its warm then gradually drop to 800!, then I drive around... Pull up and it'll idle on 2k!,Then if I switch the car off and leave for 5 mins then turn it back on it'll idle at 2k?I'm really unsure about this?... :/ cleaned the icv out with carb cleaner, also cleaned the throttle bottle out!, and I covered the throttle control in a load of wd40 and still no better? :/Really confused? Quote
Gerry Posted May 26, 2013 Posted May 26, 2013 My glanza idles around 1100-1200 rpm all the time, is that normal? Quote
Bluebear Posted May 27, 2013 Posted May 27, 2013 IIRC they should idle at around 800-850. Mine's started acting up recently, idling at 1500 when cold and down to 1000 when warm. Occasionally it drops to 850-900 with and without electrical load and then back up to 1000. Odd. Could be a bad earth. Quote
DamoC Posted May 27, 2013 Author Posted May 27, 2013 Hmmm I think you may be onto something Bluebear... I keep getting an electric shock off my car when ever I get out of it? :-o.. Any ideas or help on how I can check for a bad earth?? :-o... I'm a complete novice.. So please explain in simple terms! Real simple!, no abbreviations or anything lol! Quote
Bosotter Posted May 27, 2013 Posted May 27, 2013 (edited) Check for holes in the vacuum lines, or if a vacuum pipe disconnected by accident.As for the electric shock, I'm pretty sure that the car can not give you a jolt. Most probably static electricity from your clothes or seat covers (if fitted).... Edited May 27, 2013 by Bosotter Quote
sjbrowning7 Posted May 27, 2013 Posted May 27, 2013 I changed my coolant temperature sensor yesterday as I've been having trouble similar to yours and I think it's sorted it out. Previously I changed the ICV and lambda sensor but didn't do anything tbh. Try the coolant temp sensor anyway mate! Quote
Weyro Posted May 27, 2013 Posted May 27, 2013 Clean the idle control valve, my car used to nearly cut out when stopping at lights, now its perfext Quote
DamoC Posted May 27, 2013 Author Posted May 27, 2013 Check for holes in the vacuum lines, or if a vacuum pipe disconnected by accident. As for the electric shock, I'm pretty sure that the car can not give you a jolt. Most probably static electricity from your clothes or seat covers (if fitted).... No seat covers lol! But ill try de elcectrifying my self! Sjbrowning7 ill try that!, easy to do??? And weyro! I don't have the problem of it idling low! It's too high!! Quote
sjbrowning7 Posted May 27, 2013 Posted May 27, 2013 Yeh mate, it's the green sensor under the dizzy cap. Mine is kinda still doing a wee bit of a high/funny idle still but it's definitely not as bad now, it idles max 1250rpm but before it was all the way up at 2K. I'm going to check my tps as well this weekend and that might be the last piece to the puzzle for me. Quote
Bluebear Posted May 27, 2013 Posted May 27, 2013 Sensor may be the trick with mine, as my coolant gauge goes stupid at times, moving down in relation to the cars movement! Either a broken wire in the plug or a fucked sensor. Quote
DamoC Posted May 27, 2013 Author Posted May 27, 2013 How much was the replacement sensor?. :-), and Bluebear, any help you can give to me on check all my earths etc?? Simple diagrams would help lol! Quote
sjbrowning7 Posted May 28, 2013 Posted May 28, 2013 Think it's like 15 quid, get it from tms or a place like that. No point paying big bucks at Toyota for it. Quote
sjbrowning7 Posted May 28, 2013 Posted May 28, 2013 I taped up the wires that go into the connector that goes onto the CTS because I noticed the wires were kind of showing so that should help the connection as well, just make sure everything is pretty much perfect looking with all your connections and stuff. Quote
DamoC Posted May 28, 2013 Author Posted May 28, 2013 Will try it all this weekend cheers guys! Any help with regards to the checking of earths?? Where are these??? thanks! Quote
1991 starlet owner Posted May 30, 2013 Posted May 30, 2013 Give it a bloody good blast too fella!! Might dislodge a blockage or dirt somewhere.And yeah the static shock is from the seats mate.. Does it to my mrs all the time. You would definitely know if the car gave you an electric shock.Tom. Quote
DamoC Posted May 30, 2013 Author Posted May 30, 2013 Ahhhhh thought it might be as it doesnt always happen!! And i'll give it a good blasting see if that changed anything! Quote
