PaulStarletSR Posted May 27, 2013 Posted May 27, 2013 how much coolants required to fill my civic alloy radiator up perfectly and also the same for the power steerin fluid filled up perfectly so i know how much to buy! cheers guys! Quote
Patches Posted May 27, 2013 Posted May 27, 2013 i just got a 5L toyota red coolant which did the trick and had a good bit left over. £20 or something from toyota, no idea about power steering fluid. Quote
TurboTobz Posted May 27, 2013 Posted May 27, 2013 I'd buy the red coolant from any motor factors not sure exactley how much you'll need, probably best off getting 5L as it is handy stuff to have Quote
akyakapotter Posted May 27, 2013 Posted May 27, 2013 Power steering fluid wound red ATF fluid do that's what I've used in all my other cars Quote
PaulStarletSR Posted May 28, 2013 Author Posted May 28, 2013 how much power steerin fluid do i need tho? Quote
Liam_D Posted May 28, 2013 Posted May 28, 2013 Same here got the Toyota red stuff off iddy worked a treat! I'm sure he'll be able to sort you out with power steering stuff you need too. Quote
yaristurbo Posted May 28, 2013 Posted May 28, 2013 Couple of litres will do with some left over, Fill bottle start engine Lock steering over to left hold for 5 secs Lock steering over right hold for 5 secsTop up and repeat last 2 steps till level stays at max once is usually enough Quote
PaulStarletSR Posted May 29, 2013 Author Posted May 29, 2013 Couple of litres will do with some left over,Fill bottle start engineLock steering over to left hold for 5 secsLock steering over right hold for 5 secsTop up and repeat last 2 steps till level stays at max once is usually enoughthats awesome, cheers mate! Quote
