DamoC Posted June 5, 2013 Posted June 5, 2013 Holla!!My interior light has never worked in my ep82... I've changed fuse (I think it's the right one.. But with it being in Japanese I can't quite be sure), and I've also replaced the bulb! So..Does anyone have an English diagram for fuses for me to check? It's a 1994, ep82... And any other suggestions failing that?I've cleaned all contacts.. And still nothing!Thanks Quote
Dan Barnes Posted June 6, 2013 Posted June 6, 2013 X2 if anyone could help !! I have this problem, annoying having to use my phone light to find things at night! Quote
daniel_g Posted June 6, 2013 Posted June 6, 2013 I have this issue too, havent properly checked it out though.I have a few multi plugs which dont go anywhere, so it might be that. Quote
TrisK Posted June 6, 2013 Posted June 6, 2013 Mine stopped working in my V when i owned it too Although touch wood, my GT one works fine Quote
DamoC Posted June 6, 2013 Author Posted June 6, 2013 Not got a multimeter to check if it getting 12v.. But I can only assume it is.. As everything else in the car works! Ha Quote
Dan Barnes Posted June 6, 2013 Posted June 6, 2013 It's so annoying when something so little wont work! Quote
morgey Posted June 6, 2013 Posted June 6, 2013 Lol all I've got there is a couple of wires hanging down. Meehh cba! Quote
mark-tozer Posted June 6, 2013 Posted June 6, 2013 (edited) on both gts ive owned neither of my interior lights have worked but never really checked them out properly. Edited June 6, 2013 by mark-tozer Quote
DamoC Posted June 6, 2013 Author Posted June 6, 2013 Mines all as it should be.. (can only presume) and theres only two wires there going into a plug, which then goes into the interior light! Still no solution! Quote
daniel_g Posted June 6, 2013 Posted June 6, 2013 I kinda checked mine earlier, wasnt getting 12v at the plug. Traced the wires ( red and blue ) along the roof to the passenger A pillar, they run down that to just infront of the door and into a white/clear multiplug. Unplugged it, no corrosion, those wires run up to the dash loom, so then i thought i couldn't be fucked anymore, so i fitted my harnesses instead haha. Quote
DamoC Posted June 8, 2013 Author Posted June 8, 2013 Lol almost... Almost helpful there buddy!! Haha Quote
