Chrishoughton1989 Posted June 11, 2013 Posted June 11, 2013 When I start the car, sometimes I hear a water sloshing noise from the matrix. Is this normal ? Thanks. Quote
morgey Posted June 11, 2013 Posted June 11, 2013 I've never experienced that, sounds like you have some air in the system Quote
Chrishoughton1989 Posted June 11, 2013 Author Posted June 11, 2013 After a hard drive park it up for night and it does it in the morning. Anyone else ? Quote
StuDoc 72 Posted June 11, 2013 Posted June 11, 2013 I wouldnt worry yourself about it. If the temp gauge isnt too high it will be fine. Just check the level in your rad and overflow and youll be fine. Quote
Chrishoughton1989 Posted June 11, 2013 Author Posted June 11, 2013 Yh all levels fine. Just only done heasgasket so worried lol. I saw on other forum some cars do this ? Quote
StuDoc 72 Posted June 11, 2013 Posted June 11, 2013 Some cars do do this meganes are bad for it. When you done the head gasket did you flush out the matrix as they are known for clogging up so might be worth sticking a jet up there and flushing it out and changing over your coolant. Just keep an eye on it. Jus do all the checks and see if it is coming out anywhere. Quote
Chrishoughton1989 Posted June 11, 2013 Author Posted June 11, 2013 Ok no didn't flush matrix. Cheers will do. Quote
DamoC Posted June 13, 2013 Posted June 13, 2013 Sounds like water trickling??!? I have this too!.. And I have flushed my heater matrix.. and a load of shitty brown water came out, but i can thinking of doing it again as it didn't really change much ahha! Quote
Chrishoughton1989 Posted June 13, 2013 Author Posted June 13, 2013 Yes. Mine has stopped now lol Quote
morgey Posted July 5, 2013 Posted July 5, 2013 Anybody find a cure for this. My dads mate has an old supra with this problem, tried flushing the matrix numberous time and no luck. Quote
Jhandy Posted July 5, 2013 Posted July 5, 2013 it sounds like water pump problem, we have had a couple of cars in before changed the water pump and it goes away, dunno why, its strange lol Quote
bucketep91 Posted July 5, 2013 Posted July 5, 2013 I used to get this on my imprezza too always wondered what it was Quote
Beastmode panda Posted July 5, 2013 Posted July 5, 2013 Yeah I've had this. Frowned for a couple of minutes and just got on with driving lol. #yolo. Quote
daniel_g Posted July 5, 2013 Posted July 5, 2013 I had this on my old T sport yaris, was hundreds of leaves and vegetation in the scuttle panel causing blockages and a pool of water that sloshed about. Quote
morgey Posted July 5, 2013 Posted July 5, 2013 He reckons it only does it when its cold, so it not water in the scuttle pannel .he's also just had a headgasket changed on it as the person above tried flushing the matrix with a hose and having the front end lifted right up to try get the air out. Only wants to sell it but is reluctant too with it doing that lol Quote
daniel_g Posted July 5, 2013 Posted July 5, 2013 Was just saying in general and not really replying to anyone specific. Quote
Fozzie Posted July 5, 2013 Posted July 5, 2013 I had this on my old Saxo years ago, I changed the pump and refilled the coolant and all was well afterwards Quote
