As above really looking into plumbing in a catch can but on a budget do I need a race spec cover or is there a more cost affective way of doing this
No, you can use the original PCV pipe to run a catch can.
Beauty anyone done this and what parts or fittings were needed thanks Edited by Lawless
Breather > catch can
PCV >Catch can
Catch can > Inlet manifold
i was told it was pvc to catch can
catch can to inlet manifold
breather to open filter
Thanks very helpful saved me some pennies :). And now I can get rid of that breather on my rocker and that god damn chirping noise it's making
Would be useful too see some pics if anyone has any
Sam
Well mines tight as a nuns whispering eye tried two different filters and don't wanna over tighten it and it chirps like a motherfucker :(
So now I no I don't need a race rocker catch cans going in
:D
Thanks
But still any pics at all of this setup would be massively appreciated still new to alot of this
PCV >Catch can
The engine won't be breathing at all with that set up when on boost as the pcv will be closed so nowhere for the excess gases to go.
So which setup is correct ?
Long time dispute.
Most people say get two pcvs gut the one on the rocker put the new on between the catch can and inlet to prevent the catch can pressurising under boost.
I just have breather to catch can to keep things simple.
I've had quite a few people advise on what way to set up a catch tank.
PCV>Tank>Inlet - This way apparently pressurises the tank rather than doing any good.
PCV>Tank>Atmosphere - Apparently this is the best as the engine can breathe.
PCV>Tank>Rocker Breather - Apparently this doesn't let the engine breathe.
I had mine set up the 1st was and it caused a lot of blue smoke - I don't have connected up at all now.
Long time dispute.
Regarding the pressurised catch can when on boost, surely a one-way valve between the catch can and inlet would solve this problem?
Either way, I was lead to beleive that:
PCV >>> One way valve >>>>>>>>>>>> Catch can >>> Can exhuast to inlet before the turbo with another one way valve
Rocker breather >>> One way Valve >>> ^^^^^
Was the best method. Surely this way you eliminate any positieve crankcase pressure.
Edited by Bluebear
Basically I want my engine to breath better as it keeps blowing crankcase seals and the breather filter chirping on top is doing my fecking nut in
So a catch can setup doesn't improve the breathing in any way at all then ?
Nope!
Like I said filter shouldnt chirp if its fitted right.
Hmm I dont understand why it would bend.
Go on Autosiliconhoses and order a 12mm one and it will fit perfect. there only £5 or sumthing either that or ebay.
Ya, I said put PVC in by inlet to stop boost pressurising can the PVC is the 1 way/check valve
So the overall answer is don't use a catch can then are people running these for a reason then or is it just bling in the bay if they allow the engine to breath no more than the Pcv valve ?
