its more than wise, its what all the cool kids are doing, like cocaine
you just remove the dump valve, then block off any holes or pipes that are left over
Some say it does damage but there is no proven records of it. The only thing it causes is tiny amounts of unnoticable lag.
Personally its the way to go sounds so much better than a BOV.
Its done by taking your ssqv off and blocking off the cooler hole and the vac pipe that go to it.
  • 4 weeks later...
Chatter noise is the turbo blades stalling and will eventually damage the turbo. Be wise.
Your ssqv probably needs adjusting the spring is too hard needs loosening
Debatable
It does put some strain on the thrust bearings, however I'd expect them to be tough enough to take it for quite some time before anything noitceable happens. It's not very often you see a turbo fail due to this.
Saying that though if your only on a cheap turbo which can be picked up for a couple of skittles, then I wouldn't worry, however if your running a turbo which is like £1000+ I would run one.
Itll be fine, if it can take bar's of pressure its not going to get hurt.
It does make me laugh how some people say it completely stalls, and in some cases can spin backwards. oh trololololol
Edited by RobSR
This ^^ LOL
Surely air witch comes back out your turbo because of not having a bov isn't good in the long run! This will cause the turbo to stall Witch will make a difference to the pick up but how much depends on your set/turbo!
Garret Gtx30 turbo over £1500 squids worth and no bov does that make me a Spartan ?
It signifies a man with a large penis...
large aids infected penis though :(
Its only size that counts in a starlet
Paid a bit over the odds for that mate :sad:
Along with the v band set up, 0.71r turbine and tail exhaust housing it wasn't far off pall
