har-vey Posted July 23, 2013 Posted July 23, 2013 hello all i have a little problem, when i'm on track and down changing i can sometimes hear the exhaust knock against the chassis leg. i know its the exhaust as i held the exhaust back with a bolt but now have a horrid vibration noise, (metal on metal lol but worked OK on the day) Now i expect its just because the rear exhaust mount has got old and need replacing but i was wondering if there are any poly mounts that are a direct fit? i see Powerflex have a range of universal ones, but was wondering if anyone knows which will fit. cheers in advance Steve Quote
Spoon_tuned Posted July 23, 2013 Posted July 23, 2013 normally the back box catches the rear beam so i got some silicone from an intercooler wrapped it round the beam and clamped it on no more knocking now Quote
ryan lang Posted July 23, 2013 Posted July 23, 2013 do you drive a GT or a glanza? as the backbox hangers are different. if you have a GT, the universal one like this will be fine: http://s588.photobucket.com/user/ryanlang/media/zorstbush_zps19e384b4.jpg.html'> they both need an extra hanger between the front ones near the arb and just before the rear beam IMO Quote
Liam_D Posted July 23, 2013 Posted July 23, 2013 normally the back box catches the rear beam so i got some silicone from an intercooler wrapped it round the beam and clamped it on no more knocking nowThis was my solution! Until I got my new RW system raised to prevent it. Quote
daniel_g Posted July 23, 2013 Posted July 23, 2013 I used jubilee clamps alongside the rubber mounts as a quick fix, it was totally solid after that. Quote
har-vey Posted July 23, 2013 Author Posted July 23, 2013 I've wrapped the beam in rubber as well but ideally I don't want it hitting anything, maybe another hanger is the answer Quote
Liam_D Posted July 24, 2013 Posted July 24, 2013 Dean at Rw developments made me an additional bracket/hanger at the top if the backbox to lift it up. Works an absolute treat ill try and get a picture Quote
