EPnick22 Posted August 10, 2013 Share Posted August 10, 2013 can it be done? havnt got much money after my engine rebuild and just found my manifold has nearly split round the 1st and 4th runners, quite bad too, was thinking instead of splashing out on a new mani, to just buy a td04 but only run it on around 8-10psi, would the ecu fuel for it? I have adjustable fpr and 255 fuel pump etc, and getting it set up on the dyno once its running again Quote Link to post Share on other sites
Weyro Posted August 10, 2013 Share Posted August 10, 2013 Will fuel absolutely fine, you could run up to 0.8bar. Quote Link to post Share on other sites
mikey4410 Posted August 10, 2013 Share Posted August 10, 2013 as long as u have supporting mods will work,i ran 1 bar on td04 on ecu and fcd with other suppoting mods Quote Link to post Share on other sites
RobSR Posted August 10, 2013 Share Posted August 10, 2013 With no other fuelling mods 0.7 bar. Get a wideband on it to be safe tho. You dont want to be buying a new engine aswell id imagine! Quote Link to post Share on other sites
EPnick22 Posted August 10, 2013 Author Share Posted August 10, 2013 On 8/10/2013 at 8:23 AM, RobSR said: With no other fuelling mods 0.7 bar. Get a wideband on it to be safe tho. You dont want to be buying a new engine aswell id imagine! was thinking wideband aswell at some point, if i was to get it set up on the dyno, would the fuel mixture ever change by itself after? Quote Link to post Share on other sites
EPnick22 Posted August 10, 2013 Author Share Posted August 10, 2013 what sort of power would it run at .8 bar then? Quote Link to post Share on other sites
ep-beast Posted August 10, 2013 Share Posted August 10, 2013 people think ya can run td04 at .6 on standrd ecu without seting up fueling ya cant it is doin damage get the fueling set for .8 straight away Quote Link to post Share on other sites
EPnick22 Posted August 10, 2013 Author Share Posted August 10, 2013 well i was going to get it set up on the dyno once my car is rebuilt, do they just mess about with the FPR to get the correct AFR? Quote Link to post Share on other sites
ep-beast Posted August 10, 2013 Share Posted August 10, 2013 yes lad but it will do damage if u dont do that Quote Link to post Share on other sites
EPnick22 Posted August 10, 2013 Author Share Posted August 10, 2013 oh right sorry i thought you meant if i dont have it mapped which obviously i cant with emu or p&p yeah im definitely having it done I dont fancy blowing up a fresh engine lol Quote Link to post Share on other sites
akyakapotter Posted August 10, 2013 Share Posted August 10, 2013 Yeah you can Rbz is running a Gt28 turbo on fcd and fuel pressure reg stock ecu will be fine if set up properly Quote Link to post Share on other sites
5T4R7ET N/A Posted August 10, 2013 Share Posted August 10, 2013 with no supporting fueling mods i would only go for 0.5 on td04 on stock ecu. still will be lean on spool but will be ok. Quote Link to post Share on other sites
Liam_D Posted August 10, 2013 Share Posted August 10, 2013 Mine TD04'd on standard ECU. Been running it at 0.5bar for a few months now with a lot of hammer and its fine. Wont be long before you get bored of 0.5 though. Quote Link to post Share on other sites
RobSR Posted August 10, 2013 Share Posted August 10, 2013 0.5 bar wont be lean lol they run pretty rich. All cars vary but around .7 is what they fuel to, im not saying put it to that and itll be fine, as it may not. Get a wideband on it so you know whats going on. Quote Link to post Share on other sites
EPnick22 Posted August 10, 2013 Author Share Posted August 10, 2013 what sort of power would it make on .7 bar? Quote Link to post Share on other sites
DevonGT Posted August 10, 2013 Share Posted August 10, 2013 On 8/10/2013 at 9:29 PM, EPnick22 said: what sort of power would it make on .7 bar? Mine made 186bhp on 0.6bar. So a bit more then that. Quote Link to post Share on other sites
Ryan_EP82 GT Posted August 11, 2013 Share Posted August 11, 2013 ^^^That would near convice you change to tdo4 now lol Quote Link to post Share on other sites
EPnick22 Posted August 11, 2013 Author Share Posted August 11, 2013 well i am Quote Link to post Share on other sites
Chesh Posted August 12, 2013 Share Posted August 12, 2013 Mine made 218bhp at .8 Bar Quote Link to post Share on other sites
Ryan_EP82 GT Posted August 12, 2013 Share Posted August 12, 2013 what's the spec lol Quote Link to post Share on other sites
