liss Posted August 13, 2013 Posted August 13, 2013 Im not sure quite what the previous owner was thinking but I have an electronic Greddy boost controller in my 1996 Glanza V and a manual one which is hooked up and working :/ For some reason the Greddy is unused and has been replaced by what looks like a cheapy ebay one? First question is, is there any reason why anyone would do this and second question is what do I plug into where to get the EBC working again. Below I have provided some numbered pictures... if someone could tell me what plugs into where I would be most grateful because I have close to zero knowledge on turbos. Obviously on the first picture you can the the Greddy on the bottom the manual on the left and a random T piece on the right (im not even sure what this is for?) Hose/tube number 6 appears to come out of the top of the actuator and go no where? It is about 3-4 cm long and go no where and do nothing... is this right? Any help you guys could provide would be great as all this stuff baffles me? and while your reading this if anyone could tell me what boost would be best to have a few presets on that would be great. I was thinking 0.5 bar for everyday use, 0.65 for common use and 0.8 bar for rare use. Thanks for looking guys! Quote
monty1991 Posted August 13, 2013 Posted August 13, 2013 the last owner was drink when he fitted all this? lol rip all out an buy a hks actuator an set it for 0.6. if your not running front mount or ported mani your standard actuator is prob knackered anyways Quote
akyakapotter Posted August 13, 2013 Posted August 13, 2013 Is the controller or the greedy in the car I'd be using that if it was me thats if its not broken hence why there has been a manual one put in Quote
liss Posted August 13, 2013 Author Posted August 13, 2013 The Greddy (inside the car bit) lights up and does "stuff" when the ignition is turned on so I presume it still works... the previous owner said they changed it because it was running "funny". A few days later I found out from someone on this forum that they knew the car and that it had been running on max boost for a little while :/I would imagine they were getting the fuel cut and didnt know what the hell it was.... this is one theory anyway.... Quote
akyakapotter Posted August 13, 2013 Posted August 13, 2013 I'd hook the greedy one back up reset it and see if you can get it boosting what ever you have it set at now Quote
5T4R7ET N/A Posted August 13, 2013 Posted August 13, 2013 at the moment it looks like its only running off the actuator because the manual boost controller and the greddy control valve are not connected properly from what i can see. take the manual boost controller out and connect to the greddy control valve Quote
redz11 Posted August 13, 2013 Posted August 13, 2013 if you dont wanna keep the greddy one, if it works how much would you want? Quote
davehart Posted August 13, 2013 Posted August 13, 2013 That running on the manual boost controller. Why you would fit that if you have a greddy one I do not know. Maybe it was acting 'funny' because they did not have a clue how to set the Greddy one up or the solenoid on the greddy unit is buggered. Rip the lot out and start again Or just hook the greddy one back in and check it works. Quote
Glanza-Ben Posted August 13, 2013 Posted August 13, 2013 Yep the boost was wound right up and not set up so probs was hitting fuel cut and they as you said was probably like wtf Quote
liss Posted August 14, 2013 Author Posted August 14, 2013 Thanks everyone. I'll take a look when I get some time and get back to you! Quote
liss Posted August 17, 2013 Author Posted August 17, 2013 Hey guys can I just confirm something? A chap on toyotagtturbo forum says "If the EBC was functioning, hose #3 would go to port #2 and hose #4 would go to port #1." Is this correct before I start pulling things apart? Many thanks. Quote
