Flintygt Posted August 17, 2013 Posted August 17, 2013 Hi all. I'm after some helpful information. I have a gt turbo 1996. Non LSD gear box. I'm just wondering if any one has any idea what sort of speed I would be doing it 4 gear on the limiter?? Quote
PaulStarletSR Posted August 17, 2013 Posted August 17, 2013 i know the n/a gearbox in fourth was good for just over a ton if thats any help? Quote
Flintygt Posted August 17, 2013 Author Posted August 17, 2013 Thanks dude I know 3rd limiter at 96mph ish. Quote
mikey4410 Posted August 17, 2013 Posted August 17, 2013 My n/a sportif did 94mph in third for sure,i know thatas that was what i was doing on my trackday on a specific bit of the track time and time again. Quote
WallaceGlanza Posted August 17, 2013 Posted August 17, 2013 Depends what the limiter is set at! - 7500rpm is 140mph ish Quote
akyakapotter Posted August 17, 2013 Posted August 17, 2013 Find out in September when we cruze up to JAE Quote
Matt1878 Posted August 17, 2013 Posted August 17, 2013 Find out in September when we cruze up to JAE Do it! Throw coolant all over your engine bay too if you can! Quote
Dan Barnes Posted August 17, 2013 Posted August 17, 2013 Mines throwing coolant what's causing this? Ain't had a proper look yet Quote
RobSR Posted August 18, 2013 Posted August 18, 2013 Mines throwing coolant what's causing this? Ain't had a proper look yet At a decent speed? could be a warped head / first signs of the HG going. Quote
RobSR Posted August 18, 2013 Posted August 18, 2013 Damn use this car daily too Do a compression test / leakdown test if you can.. Quote
Dan Barnes Posted August 19, 2013 Posted August 19, 2013 Ok mate will do what should it be around roughly ? Quote
