TurboTobz Posted August 21, 2013 Posted August 21, 2013 Bedside mechanics? Are you referring to any of us? Quote
turbo Grant Posted August 21, 2013 Posted August 21, 2013 Bedside mechanics? Are you referring to any of us?I think, he thinks your talking shit. I can defiantly tell the guy before you was an animal. I don't rate the baileys valves much. Heard more bad stuff than good about them. The vac lines are really easy to sort out. Just need to get all the facts about the car and what's been done. That way you can work out what needs sorting. It would help to get better pictures Quote
LooNy Posted August 21, 2013 Author Posted August 21, 2013 No none of you I just need somone that knows what there doing because I've been on other forums and they havnt got a clue what there on about because they read crap of the Internet. And by trade there a office worker that don't even know how a engine works but read it on wiki pedia and think that's how bit is I need Someone that has had the problem or low how it works I'm not here to stay arguments, I'm a apprentice e mechanic by trade but new to jap scene, ask me about volkwagen and I could tell you straight away Quote
turbo Grant Posted August 21, 2013 Posted August 21, 2013 Also your sill on stock ht leads running 1.1 bar. I bet they have never been changed in the last 13+ years odd. Updates ones are far cheaper the the £140 odd from toyota Quote
TurboTobz Posted August 21, 2013 Posted August 21, 2013 No none of you I just need somone that knows what there doing because I've been on other forums and they havnt got a clue what there on about because they read crap of the Internet. And by trade there a office worker that don't even know how a engine works but read it on wiki pedia and think that's how bit is I need Someone that has had the problem or low how it works I'm not here to stay arguments, I'm a apprentice e mechanic by trade but new to jap scene, ask me about volkwagen and I could tell you straight awayI've vehicle mechanic qualifications, expirience, I then moved onto an apprenticeship in heavy engineering and electrical I have all relevant qualifications plus a load of extras work was including fabrication welding hydraulics engines pneumatics heavy plant electrical electronic industrial and domestic electrics, along with a lot of other skills, and at the moment I'm serving as a tool and machine setter using engineering hydraulics pneumatics maintenance fault finding(why things are being rejected and altering programming and profiles to iron out faults within the moulds) and working with 6 axis robotics as well as pneumatic robotic systems within the plastics production industry you can be assured I'm not a pen pusher behind a keyboard, I do a lot of work on cars be it my own, families or friends. I've never had my car in a garage apart from the odd MOT.I'm happy to help out with vac routes take some more pictures as there's possibly other bits that need addressing also. There not massively clear but I am on my phone I'll get on my laptop tomorrow and have a look if no one else does anything before me. Quote
LooNy Posted August 22, 2013 Author Posted August 22, 2013 Ok thank you Everyone and tobz and grant and ill get some better pics. Quote
LooNy Posted August 22, 2013 Author Posted August 22, 2013 here are all the pics of my car http://s798.photobuc...w=recent&page=1 see if you can help thanks connor Quote
TurboTobz Posted August 22, 2013 Posted August 22, 2013 Right, first off I'd remove the hi/lo boost solenoid, it can be unplugged and taken off no issues this will also remove a restriction.I'm guessing the A/C has been removed, if so you can remove the vac hosing to the right of the intake manifold, and un plug and discard the sensors.Dedicate one of the spare nipples to the boost gauge, then plug the hole left in the T piece or remove it and link the pipes up or replace the pipe, or remove that dump valve (That could be giving you some issues).Is there a boost controller? How to remove the boost solenoid (restricts 1'st and 2'nd)http://www.toyotagtturbo.com/forums/showthread.php?2277-Hi-Low-Solenoid-Bypass Quote
TurboTobz Posted August 22, 2013 Posted August 22, 2013 Remember to plug any left over nipples, or anything else you'll get vac leaks Quote
LooNy Posted August 22, 2013 Author Posted August 22, 2013 I didn't fit any of it I brought it like it and its done badly Quote
TurboTobz Posted August 22, 2013 Posted August 22, 2013 yea, just iron out the faults and tidy it up. Quote
LooNy Posted August 22, 2013 Author Posted August 22, 2013 I dot know if I got a boost controller I know I have a boost gauge lol I have no a/c And I got the high and low turbo and one of the vaccum pipes on it is disconnected Quote
LooNy Posted August 22, 2013 Author Posted August 22, 2013 Well where the high and low boost use to be Quote
turbo Grant Posted August 22, 2013 Posted August 22, 2013 The pipe T'ed off you actuator go to the stock boost control valve? That pipe should go to some form of boost controler. Quote
TurboTobz Posted August 22, 2013 Posted August 22, 2013 Grant if you look closely it looks to me as if that pipe actually runs to the dump valve? looks like it's under the slam panelActuator should be and probably is (if my assumption is correct) taken from the side of the turbo Quote
LooNy Posted August 22, 2013 Author Posted August 22, 2013 T piece goes to dump valve definatly and in the baulk head to the boost gauge I think ? Quote
TurboTobz Posted August 22, 2013 Posted August 22, 2013 I'd say so, dedicate it it's own line it's tidier and keeps things simple. Your bays full of carbon judging by them pics weld/replace manifold and gaskets that should help out a lot... Quote
LooNy Posted August 22, 2013 Author Posted August 22, 2013 Yea it some sort of sealer they tried stoping the leak with black gasket sealer but it hasn't worked aha so instea of the t piece what shall I swap it for ? Quote
TurboTobz Posted August 22, 2013 Posted August 22, 2013 Straight bit of hose, or cut a small bit of hose off put it on the t piece nipple that needs blanking and plug it with a bolt if you have no hosing spare Quote
TurboTobz Posted August 22, 2013 Posted August 22, 2013 just a short bit of hose to replace the spare nipple you'll have on that tee piece once you single your vacuum lines down to separate sources/feedsobviously that short bit of hose needs to blank the open nipple left on the t piece which can be done with a bolt Quote
turbo Grant Posted August 22, 2013 Posted August 22, 2013 Run a tube off the small nipple facing forward on the inlet manifold to your dump valve. T off the fuel regulator on the end of the fuel rail for the boost gauge. The turbo to actuator pipe. You would want to get some form of boost controller and a new manifold as well Quote
TurboTobz Posted August 22, 2013 Posted August 22, 2013 Why do you say tee off of fuel reg vacuum grant not that I'm questioning you, just intrigued lol Quote
turbo Grant Posted August 22, 2013 Posted August 22, 2013 Most boost controllers and stuff like that say T off the fuel reg line for pressure. It's just an easy pipe to use. I like to keep it dedicated tho. But it won't hurt if to take a pressure signal from it Quote
