  • Replies 130
So the heaters were poor, got a pipe and motor from Daniel-g cheers pal
Was still not brilliant so pulled out the pollen filter blocked solid :) fixed now
Found a fcd in there too
85B6BD8A-5DDC-4D94-B1F3-C08B4A089074_zps
Gonna pull the skirts off tomorrow and clean up/treat the metal work as spent all week welding another car it wasn't fun
Edited by yaristurbo
Are the rear bottom lights both on the same filament mate?
Looks like the passenger side bottom is on the 21w filament and the drivers side bottom is on the 5w filament, They should both be on the 5w filament if you use them as your sidelights :)
Edited by Jamie5414
