coxycox Posted October 4, 2013 Posted October 4, 2013 Sorry to start another thread guys as im sure this has been asked before but im just struggling to find it! Can anyone shed some light.. Quote
WallaceGlanza Posted October 4, 2013 Posted October 4, 2013 The lsd is external to the box on the drivers side so it's pretty obvious, it should also come with the shorter driveshaft on that side. Quote
coxycox Posted October 4, 2013 Author Posted October 4, 2013 Cheers mate! Do you have a picture for an example? Im going to buy one on sunday i just need to be 100% its an LSD Quote
RobSR Posted October 4, 2013 Posted October 4, 2013 Just make sure the shafts are both basically the same length, and you have the rear gearbox mount also. i dont have a pic but im sure someone will post one up. Quote
coxycox Posted October 4, 2013 Author Posted October 4, 2013 Alright cheers guys! So the shafts will be different length.. and the diff is mounted on the outside of the gearbox.. anything else to look out for? Quote
morgey Posted October 4, 2013 Posted October 4, 2013 Look in the wiki section on the top bar mate theres a thread describing it with pictures Quote
RobSR Posted October 5, 2013 Posted October 5, 2013 Alright cheers guys! So the shafts will be different length.. and the diff is mounted on the outside of the gearbox.. anything else to look out for? No standard shafts are massively different lengths, the OEM LSD gearbox shafts are nearly exactly the same length both sides. Quote
coxycox Posted October 6, 2013 Author Posted October 6, 2013 (edited) Thanks for that guys! Ive been and picked it up today and it all checks out. What gearbox oil is best to use? Obviously it is a standard LSD box i have now. Does anyone have a link to a good website for some? Also is it a measured quantity or just fill up untill it comes out? Edited October 6, 2013 by coxycox Quote
RobSR Posted October 6, 2013 Posted October 6, 2013 Get onto opie oils and get something reasonably good. Theres a level bolt on the side, take that off, take the fill bolt off the top, fill untill it drips out the side. Put both bolts back in. Easy stuff. Quote
morgey Posted October 6, 2013 Posted October 6, 2013 As above Opie Oils, redline, millers, etcI dont believe the OEM LSD requires LSD oil just normal stuff Quote
coxycox Posted October 7, 2013 Author Posted October 7, 2013 Cheers guys! What grade is best to use? Or shall I just ask opie oils on here? Quote
Banbury Glanza Posted October 7, 2013 Posted October 7, 2013 Might be wrong here but I was told to use LSD oil in my OEM LSD Quote
RobSR Posted October 7, 2013 Posted October 7, 2013 I was also under the impression you just used normal stuff. Think 75-90 is the norm off the top of my head. Quote
coxycox Posted October 8, 2013 Author Posted October 8, 2013 So its looking like I should just some good quality 75w90.. I want to give the gearbox a good clean before I put it on the car. Is it going to be ok to jetwash it? Quote
RobSR Posted October 8, 2013 Posted October 8, 2013 Id get a decent brush / wire brush and give it a good scrub with an engine bay degreaser. Quote
corofin12345 Posted October 8, 2013 Posted October 8, 2013 (edited) 1. LSD on outside of box on drivers side2. shorter divers side drive3. passenger side drive is stock size4. rear gearbox mount is different, both bracket and mount itself5. sandwhich plate is different Edited October 8, 2013 by corofin12345 Quote
coxycox Posted October 9, 2013 Author Posted October 9, 2013 Cheers mate, it all checks out to be a lsd box so I didn't get ripped off lol. I just cant wait to start the conversion now. Who is best to speak to about doing an auto to manual conversion? Quote
RobSR Posted October 9, 2013 Posted October 9, 2013 how mechanically competent are you? if youve got the time its not technically too hard to do! Quote
coxycox Posted October 9, 2013 Author Posted October 9, 2013 I work on motorbikes for a living so cars are not too bad. Anything in particular to watch out for? The main thing im worried about is mounting the pedals.. are all the bolt holes going to be there for the clutch? Quote
