identifying an OEM lsd box
  On 10/4/2013 at 10:26 PM, coxycox said:
Alright cheers guys! So the shafts will be different length.. and the diff is mounted on the outside of the gearbox.. anything else to look out for?
No standard shafts are massively different lengths, the OEM LSD gearbox shafts are nearly exactly the same length both sides.
Thanks for that guys! Ive been and picked it up today and it all checks out. What gearbox oil is best to use? Obviously it is a standard LSD box i have now. Does anyone have a link to a good website for some? Also is it a measured quantity or just fill up untill it comes out?
Edited by coxycox
Get onto opie oils and get something reasonably good. Theres a level bolt on the side, take that off, take the fill bolt off the top, fill untill it drips out the side. Put both bolts back in. Easy stuff. :)
I work on motorbikes for a living so cars are not too bad. Anything in particular to watch out for? The main thing im worried about is mounting the pedals.. are all the bolt holes going to be there for the clutch?
