just wondering if its safe to run my blitz plug & play when i go td04 has anyone had problems doing this before?
good & bad points?
safest way to do this?
thanks matt
Quite a few people seem to run the Blitz/Jams etc on TD04's at around 1bar. Just get the fuelling checked to make sure all is well and as should be.
U can run a td04 on standard management at 10 psi fine so a plug in and play will happily run 14 psi.
I would not go over 14 psi as injectors arent far of maxing at this.
  • 2 weeks later...
I read some even went to 18psi with this setup with an uprated fuel pump , FPR etc.
A wideband is a must.
I have a JAM ecu and once you go over 10psi, AFR is at 10 flat.....you can occasionally see 10.5-11 but that is quickly brought back to 10 flat on the wideband.
Use proper fuel and change your fuel filter as well.
