Beastmode panda Posted November 12, 2013 Posted November 12, 2013 After tightening the drive shaft nut on the weekend the front wheels don't spin freely? They're proper grindy too. I've just ordered new wheel bearings so hopefully that will be my answer? Any ideas as to why they are so tight? Quote
turbo Grant Posted November 12, 2013 Posted November 12, 2013 (edited) Are you using non abs shafts?And dis you move the car withouth the drive shafts in? Edited November 12, 2013 by turbo Grant Quote
yaristurbo Posted November 12, 2013 Posted November 12, 2013 Try giving the shaft a tap with a coppe hammer and recheck sounds like bearing not sat right Quote
yaristurbo Posted November 12, 2013 Posted November 12, 2013 I had it with my gt the shaft was hitting the hub, can't remember what I did think was new bearings as I towed it without shafts in Quote
AdamB Posted November 12, 2013 Posted November 12, 2013 Did you torque the nut to the right spec? Over tightening will cause bearing issues. Quote
Beastmode panda Posted November 12, 2013 Author Posted November 12, 2013 Are you using non abs shafts?And dis you move the car withouth the drive shafts in? ohh my god!!, I never thought of that!! Yeah I am, as the gt didn't have ABS!!!!!! Fuck. Nope never moved the car without shafts in. Quote
turbo Grant Posted November 12, 2013 Posted November 12, 2013 Did you torque the nut to the right spec? Over tightening will cause bearing issues.I've never ever torqued front hubs up lol always do mine FT Quote
yaristurbo Posted November 12, 2013 Posted November 12, 2013 Ft or 3 duh duh duh with snap on gun Quote
turbo Grant Posted November 12, 2013 Posted November 12, 2013 Ft or 3 duh duh duh with snap on gunYou know the score haha Quote
daniel_g Posted November 12, 2013 Posted November 12, 2013 I've never ever torqued front hubs up lol always do mine FTFt or 3 duh duh duh with snap on gunSwinging off the end of a 24" bar, scaffy pole attached, feet off the ground haha. Quote
turbo Grant Posted November 12, 2013 Posted November 12, 2013 Swinging off the end of a 24" bar, scaffy pole attached, feet off the ground haha.Now that's just silly Quote
daniel_g Posted November 12, 2013 Posted November 12, 2013 It works lol. Ive never had a come-back in work yet for any wheels or mounts etc coming loose. FT is the best way !! Within reason of course Quote
