1991 starlet owner Posted November 13, 2013 Posted November 13, 2013 (edited) Year: 1991Model: ep82 gt turbo mk1Tax:may 2014MOT: 30 may 2014Mileage:172,000kmDescription:Hello and welcome to my advert for my mk1 ep 82 starlet gt turbo (which are quite rare now). It has approximately 172,000 km on the clock (so roughly 110,000 miles) which will go up slightly as its still in daily use. It is taxed until may 2014 and doesnt need an mot until 30 may 2014. The car is a great little runner and benefits from the following;Good bits. - Warlbro 255hl fuel pump - Brand new RAC battery - Aircon removed - Nur spec r stainless steel de cat exhaust system (too early for emissions test!!!!) also lifted as these systems sit very low but mine sits higher to avoid speed bumps more easily - Autogauge boost gauge approx 30mm (stuck on with sticky on drivers side so can be easily removed with no holes in the dash) - OMP steering wheel with long boss - Recaro bucket seat (some rips on right side bolster getting in and out) - Blue willians harness for drivers seat - Moster motorsport air filter relocation kit to front bumper - Aftermarket actuator (may be apexi or blitz but unsure) - Blitz supersound BOV (with two settings) - Was told by previous owner the manifold has been ported - Was told by previous owner the downpipe has been gutted - Coilovers on the front have been told theyre Tein coilovers (standard springs - lowered ones and shocks on back) - Mk1 standard boost gauge that creeps round in a circle on the bottom of the rev counter -Wedsport 13 lightweight alloys - Clifford alarm system with built in turbo timer (AVANT GUARD 5) no certificate unfortunately but i found the correct manual online and downloaded to check it was the same model and im 99% sure its the one. - Iridium heat range 7 spark plugs - Brand new king lead magnecore (a month old) with the rest of the brand new set to go on (will be included for buyer) Not so good bits Last mot advisories are as follows; 001 Rear (both) rear wheel bearing has slight play 002 Nearside front upper shock absorber has a slightly worn bush 003 Front (both) brake disc worn, pitted or scored, but not seriously weakened 004 Rear (both) brake disc worn, pitted or scored, but not seriously weakened 005 Rear tyres perishing. As far as i am aware the rear wheel bearings are a fairly simple job to do as are the other advisories, it just needs some TLC really. As far as the body work is concerned it needs some attention. Its a 23 year old car so the paint has started to peel in a few places and generally looks tired. There are a fair few stone chips towards the bottom of the front bumper but as far as rust is concerned I am not aware of any. There may be a little bubbling on the rear wheel arches will check tomorrow at work. Also, I believe that the turbo seals will need doing as on boost there is some blue smoke that exits the exhaust. Apart from that I do not get any white smoke, just slight blue on boost to represent some oil getting through. Also I have changed the thermostat housing recently as my old one started to leak. So it has had a coolant leak but has NOT overheated, just lost minimal fluid and this is now sorted!!! The drivers window needs a new regulator to which I have but its an ep91 connection so the old connection (still in the door ready to be changed) soldered on will work fine. The sunroof starts to open and then stops so that will need looking at too. I had a slight knock in the car last Saturday evening (09/11/2013), the nearside front indicator was hit and the glass broke (have amost if not all pieces so may be able to stick back together) but the indication still works fine!!! The car also suffered a small dent as shown in photos. The only reason I'm selling the car is because I'm picking up a new car saturday and can't have two my parents say as we have no more room. I love this car and it's brilliant to drive, I've had a lot of fun in it. But the time has come to pass on to someone else who will enjoy it rather than it sat on a driveway not being used. I may have missed a few things so any questions are welcome! Many thanks for reading my advert of my MK1 EP82 GT turbo. Tom. Price: £1050 O.V.N.OPictures:http://s1288.photobucket.com/user/tomwaller1/media/NewForest-20111218-00051_zps8d290e16.jpg.html?sort=3&o=0 http://s1288.photobucket.com/user/tomwaller1/media/IMG-20110925-00034_zpsdbad39f1.jpg.html?sort=3&o=1 http://s1288.photobucket.com/user/tomwaller1/media/IMG-20110925-00032_zps72c875ef.jpg.html?sort=3&o=2 http://s1288.photobucket.com/user/tomwaller1/media/IMG-20110830-00016_zps241ca210.jpg.html?sort=3&o=4http://s1288.photobucket.com/user/tomwaller1/media/IMG_1461_zpse9b7d517.jpg.html?sort=3&o=15 http://s1288.photobucket.com/user/tomwaller1/media/IMG_1462_zps8ef376ce.jpg.html?sort=3&o=14 http://s1288.photobucket.com/user/tomwaller1/media/IMG_1463_zpse00cdfc5.jpg.html?sort=3&o=13 http://s1288.photobucket.com/user/tomwaller1/media/IMG_1464_zpsf707e0b8.jpg.html?sort=3&o=12 http://s1288.photobucket.com/user/tomwaller1/media/IMG_1465_zps903b2dd8.jpg.html?sort=3&o=11 http://s1288.photobucket.com/user/tomwaller1/media/IMG_1466_zpsd4fbfc48.jpg.html?sort=3&o=10 http://s1288.photobucket.com/user/tomwaller1/media/IMG_1467_zps373d3477.jpg.html?sort=3&o=9 http://s1288.photobucket.com/user/tomwaller1/media/IMG_1468_zps1b836cca.jpg.html?sort=3&o=8 http://s1288.photobucket.com/user/tomwaller1/media/IMG_1469_zpsb91b4191.jpg.html?sort=3&o=6 http://s1288.photobucket.com/user/tomwaller1/media/IMG_1470_zps16d88014.jpg.html?sort=3&o=5 http://s1288.photobucket.com/user/tomwaller1/media/IMG_1471_zps41bf1cd4.jpg.html?sort=3&o=4 http://s1288.photobucket.com/user/tomwaller1/media/IMG_1472_zpsd77605f3.jpg.html?sort=3&o=2 http://s1288.photobucket.com/user/tomwaller1/media/IMG_1473_zpscb0a55ae.jpg.html?sort=3&o=0 --- CD player shown is not included in sale.Contact Details: PM me or text Tom on 07901343736 Edited December 7, 2013 by 1991 starlet owner
1991 starlet owner Posted November 19, 2013 Author Posted November 19, 2013 (edited) That's very cheap mate wowI know mate, priced to sell as really it needs to go by this time next week. I was gonna advertise for more £1400 ish but that was before the need of a quick sale as I'm picking up my new 04 330CD Saturday:DTom. Edited November 19, 2013 by 1991 starlet owner
redz11 Posted November 19, 2013 Posted November 19, 2013 glwts dude, someone snap up this glow badge GT! very honest advert too, nicely laid out. very cheap too!!! I want a glow badge
1991 starlet owner Posted November 20, 2013 Author Posted November 20, 2013 glwts dude, someone snap up this glow badge GT! very honest advert too, nicely laid out. very cheap too!!! I want a glow badgeThanks, if people know what they're buying it's a lot easier for everyone:DTom.
1991 starlet owner Posted November 20, 2013 Author Posted November 20, 2013 Oohh also lads,It's always cooled down on the turbo timer through the alarm which lasts for a minute, and if cold only driven under 3000rpm and NO boost until warmed up fully.Thanks,Tom.
Darraghmh91 Posted November 20, 2013 Posted November 20, 2013 (edited) This is seriously cheap i only paid 2300 for my mk one gt and this is a very very rare sun roof modle Im sick now i want this ha .. People get the finger out and buy this puppy its the deal of the year Edited November 20, 2013 by Darraghmh91
jezza Posted November 20, 2013 Posted November 20, 2013 Shame you're so far away. Would have been keen on this
1991 starlet owner Posted November 20, 2013 Author Posted November 20, 2013 Shame you're so far away. Would have been keen on thisWhere abouts are you mate? The car could be viewed etc in Chichester from this weekend.Thanks,Tom.
1991 starlet owner Posted November 20, 2013 Author Posted November 20, 2013 Glasgow! Oohh haha, was gonna say meet half way but perhaps not.. Bloody long trip. Driven up to the fringe a couple of time with my bro and fiancée in Edinburgh.Tom.
1991 starlet owner Posted November 20, 2013 Author Posted November 20, 2013 Where abouts r u mate?New Milton mate, bh25, or Chichester for the weekend PO197NW.Tom.
Mohsin butt Posted November 21, 2013 Posted November 21, 2013 Which one is nearest to Nottingham mate????
1991 starlet owner Posted November 21, 2013 Author Posted November 21, 2013 My phone map says 3h:50 mins from Nottingham to Chichester and from you to new Milton is 4 mins different, but as of Saturday car will be in Chichester.Many thanks,Tom.
Ep91sleep Posted November 21, 2013 Posted November 21, 2013 Would you consider a swap? I've got 5door 4efte conversion 6000miles on engine since it was rebuilt, only 5door sleeper in the UK
1991 starlet owner Posted November 21, 2013 Author Posted November 21, 2013 Would you consider a swap? I've got 5door 4efte conversion 6000miles on engine since it was rebuilt, only 5door sleeper in the UKHiya mate,Thanks for the reply but it's a cash sale only I'm afraid. No room unfortunately.Good luck with your sale though! Tom.
_shaun_ Posted November 22, 2013 Posted November 22, 2013 I'd be tempted to buy it and break it but am scared what Marc moss would do to me at the next show
Ep91sleep Posted November 22, 2013 Posted November 22, 2013 If you break Im putting dibs on front splitter and air filter relocation mate
Mohsin butt Posted November 23, 2013 Posted November 23, 2013 If u break it mate I'll have the engine please
Johnny-C Posted November 23, 2013 Posted November 23, 2013 Id be on the plane over for this but im not home until June next year.dam it!
1991 starlet owner Posted November 25, 2013 Author Posted November 25, 2013 Bumpdy bump, I won't be breaking as don't have the time but someone would make a fair mint if they bought and broke this.Tom.
daniel_g Posted November 25, 2013 Posted November 25, 2013 Bumpdy bump, I won't be breaking as don't have the time but someone would make a fair mint if they bought and broke this.Tom.Cough *Hawwy* Cough, lol.Nobody break it please its just wrong on every level.GLWS Tom, hope it goes to a good home, shame you are 400 miles away :/ lol.
MARC MOSS Posted November 25, 2013 Posted November 25, 2013 Cocks why the fuck has the break it word been mentioned it's a fucking mk1
