the second one looks like your fan plug. where its connected near the battery tray, with it unplugged you fan its on constantly, so its clearly not power but control/signal probably from ECU/thermostat
someone will undoubtedly correct me if im wrong.
Phil
I'd say more like aircon stuff in that location
1st one runs along the front loom but duno what its for.
2nd one plugs into the AC pump iirc.
Yup thats what it is, if you dont bridge that plug after removing aircon your fan will stay on constantly as the circuit is broken.
Phil
Edited by Philm
Phil
I know the one you mean Phil but its not that one, there is a sensor which is located in an AC pipes that plugs into the other plug, that is near the battery area.
haha i knew i would be wrong, for the record all the plugs look the same to me, period.
Phil
