Just had a nightmare rotating my turbo to miss the oil filter and one of the pipes coming from the housing is wanting to sit where my manifold is any ideas please? Can I cut it down to size or ....
Thanks
im sure its the oil return but that should be facing the floor, im struggling with pictures to put on here as my photobook wont work :sad:
Yup it's deffo the oil return mate but it's facing towards the mani, I guess you have to rotate that too so it's facing the floor?
on the TD04... You need to rotate all three parts of the turbo..
Compressor needs to point down.
Core, return needs to point straight down.
Exhaust Housing, will need rotating to suit whatever angle your downpipe has been made too!
Any pointers on how to make it a bit easier? Will I need to remover the fins inside the tubby?
Nope... The Core Stays in tact.. Your removing the housings off each side and spinning them!
The Core (shaft, turbines, bearings, seals) is one piece. Don't take that apart...
It will be stuborn. You will need Oxy Cet to get the exhaust housing off and a rubber mallet!
Thanks for the offer Liam (top man) . After a bit of heat she came off a treat and she's now fitted to the car :-) I'll have to try get some pictures up on my build thread but photobook never wants to work with me and no one looks on my progress anyway sad times!
My computer just doesn't like it and my phone won't let me use it either :-( , hmm hopefully in feb properly on the road matey!
