jayc-glanza17 Posted November 17, 2013 Posted November 17, 2013 map sensor been checked??if its popped or a slit hose, it will run rough as hell..if you have a spare maybe worth swapping over. Quote
Beastmode panda Posted November 17, 2013 Author Posted November 17, 2013 map sensor been checked?? if its popped or a slit hose, it will run rough as hell.. if you have a spare maybe worth swapping over. I don't think I have a spare one man nope .. I'll check over that though! Took the plugs out and they were black as hell, all of them!! So wire bushed them up n they are shining and they were already gapped to 0.8 so that's good. I think it might be my fuel pump? Just turned the car on to try the plugs and sat inside and it sounds fucking rank, the fuel pump doesn't sound like the normal 255 buzz it sounds proper proper horrible like an aux belt squeak!!! Quote
GP82 Posted November 17, 2013 Posted November 17, 2013 Sounds ignition related, like spark not reaching the plugs, check the distributor cap for cracks. Inspect the rotor arm, king lead and plugs. Quote
Beastmode panda Posted November 17, 2013 Author Posted November 17, 2013 Sounds ignition related, like spark not reaching the plugs, check the distributor cap for cracks. Inspect the rotor arm, king lead and plugs. Hmm, will have to inspect further around that area then yeah. Will check dizzy etc! Quote
TurboTobz Posted November 17, 2013 Posted November 17, 2013 post up a video, stock fuel pressure is 2.4bar area, if you can post a video of the way it's running we maybe able to give some more helpful info Quote
Beastmode panda Posted November 17, 2013 Author Posted November 17, 2013 (edited) post up a video, stock fuel pressure is 2.4bar area, if you can post a video of the way it's running we maybe able to give some more helpful info Ignore the rattle type noise, it was just my boost pipe on the chassis lol, I held my hand on it half way through the vid to stop it. Edited November 17, 2013 by Rbz. Quote
TurboTobz Posted November 17, 2013 Posted November 17, 2013 Can hear that hunting, sounds like a bit of a knock/tap is that just the affect of the video? It's not incredibly easy to hear when you say running shit, what exactly are the symptoms? does it behave as it should on boost? Quote
Beastmode panda Posted November 17, 2013 Author Posted November 17, 2013 Can hear that hunting, sounds like a bit of a knock/tap is that just the affect of the video? It's not incredibly easy to hear when you say running shit, what exactly are the symptoms? does it behave as it should on boost? Just the video, other things rattling like boost pipes lol. It's rough, bogy, very very low idle compared to normal and not smooth at all. It doesn't hunt anymore but the other stuff is still the same. And I don't know, I don't want to hit boost incase it dets. Then I really will be in the shit. But for argument sakes I should imagine not no. Fuel pump sounds weird as mentioned above and have been suggested map sensor too. So I really do not know. I'm going to check over the ignition side of things i.e dizzy and rotor arm and change king lead as I have a spare one. Quote
TurboTobz Posted November 17, 2013 Posted November 17, 2013 Try the original pump, does sound like it could be map sensor, has the timing been fiddled with at all ignition or engine? Can you compression test it for piece of mind? Did it get tested before you got it? Change the pressure reg or the setting to same as old. I have a few bits here if you need anything let me know I may have other engine bits left laying around that could be worth trying but sounds like you have most. Can you try that old MAP sensor that was on your car before I changed it? Quote
Beastmode panda Posted November 17, 2013 Author Posted November 17, 2013 Try the original pump, does sound like it could be map sensor, has the timing been fiddled with at all ignition or engine? Can you compression test it for piece of mind? Did it get tested before you got it? Change the pressure reg or the setting to same as old. I have a few bits here if you need anything let me know I may have other engine bits left laying around that could be worth trying but sounds like you have most. Can you try that old MAP sensor that was on your car before I changed it? I don't have it, got rid of that ages ago, the 255 has been ok for over a year now surprising for an ebay one.. I honestly don't know, but i'm going to get it checked! Nope, because I know the car it came out of so I didn't check compression or anything.. Had no reason to tbh. I don't know where that has gone either man haha, might be in the shed in a box but if not do you have a spare oem map sensor? Quote
TurboTobz Posted November 17, 2013 Posted November 17, 2013 unfortunately i don't have a spare MAP, is the fuel pressure getting up and holding as it should? Quote
Beastmode panda Posted November 17, 2013 Author Posted November 17, 2013 unfortunately i don't have a spare MAP, is the fuel pressure getting up and holding as it should? Ah ok man no worries, I did put a wanted thread up so hopefully someone will reply to it soon! Yeah, holds pressure fine. Quote
jayc-glanza17 Posted November 17, 2013 Posted November 17, 2013 have you also checked the dizzy cap for moisture??was the car better once warm and upto temp?? Quote
Beastmode panda Posted November 17, 2013 Author Posted November 17, 2013 Ohhhhh shit son I am the don. Fucking fixed It yooo. Quote
akyakapotter Posted November 17, 2013 Posted November 17, 2013 Ohhhhh shit son I am the don. Fucking fixed It yooo.What was it ?? Quote
Beastmode panda Posted November 17, 2013 Author Posted November 17, 2013 That's confidential aky! ......................... Quote
akyakapotter Posted November 17, 2013 Posted November 17, 2013 That's confidential aky! ......................... Haha come on mine dose this every now and then I wanna no lmao Quote
Beastmode panda Posted November 17, 2013 Author Posted November 17, 2013 Map sensor vacuum came off LOOL. Didn't even see it, went to unplug the map sensor to see if it changed the idle and realised it had come off. So zip tied it back on now all is good, perfect idle again . Come on, we've all been there right Quote
jayc-glanza17 Posted November 17, 2013 Posted November 17, 2013 glad you sorted it mate..Map sensor is what I felt it would be, and yep most people doing an engine swap have done that..glad was an cheap fix. Quote
TurboTobz Posted November 17, 2013 Posted November 17, 2013 Fuel pressure sort it before boosting, otherwise your in melting terrotory Quote
Beastmode panda Posted November 17, 2013 Author Posted November 17, 2013 My fuel pressure is fine. Conversation above was cause the guy asked that's all. Quote
TurboTobz Posted November 17, 2013 Posted November 17, 2013 The only thing I haven't done since putting the new engine is turn up the fuel pressure to what it was on my old engine (4 bar). It's currently on 3bar, so would that be the issue? The fact I boosted at over a bar of boost on only 3bar of fuel???? ^3Bar will be running lean on something flowing that of a GT28@1Bar Quote
Beastmode panda Posted November 17, 2013 Author Posted November 17, 2013 Yeah that was on the fpr that was on the engine when we took it out, I've put my old one on it now so it's correct . Quote
GlanzaJim Posted November 20, 2013 Posted November 20, 2013 Rob love it how you said "checked all vac pipes" and one was of haha Quote
