Drill the head off remove the rest of the bolts as normal, take the head off then you could weld a nut onto the remainder of the bolt that's sticking out the block and undo it that way.
^^ do this bud but you wont need to weld a nut on the stud,
just use a pair of pliers or mole grips and just wind it out the block it will come out easy as it wont be under pressure or load
