maddox710 Posted November 30, 2013 Share Posted November 30, 2013 How to get a rounded head bolt out? Must have been cheap nasty after market rounded like cheese. Any suggestions guys? Quote Link to post Share on other sites
Liam_D Posted November 30, 2013 Share Posted November 30, 2013 What bolt is it?? What does it mount too? Quote Link to post Share on other sites
fremyjay Posted November 30, 2013 Share Posted November 30, 2013 get an old socket hammer it onto the bolt and undo, if worst comes to worst drill it out and rethread the hole Quote Link to post Share on other sites
maddox710 Posted November 30, 2013 Author Share Posted November 30, 2013 Its a headbolt (cylinder head bolt) Quote Link to post Share on other sites
morgey Posted November 30, 2013 Share Posted November 30, 2013 Drill the head off remove the rest of the bolts as normal, take the head off then you could weld a nut onto the remainder of the bolt that's sticking out the block and undo it that way. Quote Link to post Share on other sites
russ78 Posted November 30, 2013 Share Posted November 30, 2013 Drill the head off remove the rest of the bolts as normal, take the head off then you could weld a nut onto the remainder of the bolt that's sticking out the block and undo it that way. ^^ do this bud but you wont need to weld a nut on the stud, just use a pair of pliers or mole grips and just wind it out the block it will come out easy as it wont be under pressure or load Quote Link to post Share on other sites
aidanep71 Posted November 30, 2013 Share Posted November 30, 2013 Happened mine I just beat a slightly bigger torque into it and it flew out Quote Link to post Share on other sites
maddox710 Posted November 30, 2013 Author Share Posted November 30, 2013 Still need to crack it loose Quote Link to post Share on other sites
yaristurbo Posted November 30, 2013 Share Posted November 30, 2013 Smack the next size up into it Quote Link to post Share on other sites
aidanep71 Posted November 30, 2013 Share Posted November 30, 2013 It will loosen when your beating in a bigger size it's exactly what happened mine Quote Link to post Share on other sites
