Zeldoz Posted December 2, 2013 Posted December 2, 2013 Basically, Finished buying my Zisco ram horn TD04. My setup will be; Zisco Ramhorn ManifoldDecatTD04Turbosmart/TIAL 38mm Wastegate (0.6bar spring)FMICNo BOVHKS Hi Power Would this setup be able to run at 0.6bar on the wastegate without mapping? Basically, I'm inpatient as fook. So i'd like to slap this on over my holiday over xmas. I haven't got a SAARD FPR or Wideband yet, but since im runing below factory fuel cut i think it would be ok? Then Febauary, im planing to have it mapped on E-Manage Blue/Ultimate. Opinions,Feedback or advice would be great. Quote
micky boy Posted December 2, 2013 Posted December 2, 2013 Will be fine mate the ecu can fuel anything below fuel cut so just keep the boost down below fuel cut lol Quote
Zeldoz Posted December 2, 2013 Author Posted December 2, 2013 Will be fine mate the ecu can fuel anything below fuel cut so just keep the boost down below fuel cut lol was going to chuck a 0.6bar spring. Which is well below cut.. being ex.gated i guess it wont creep.. (hopefully) Quote
jayc-glanza17 Posted December 2, 2013 Posted December 2, 2013 .6bar spring will be fine mate..I did that set that whilst I wasn't forged etc... ran fine bud. leave it at that boost till you have management. Quote
TurboTobz Posted December 2, 2013 Posted December 2, 2013 Be fine, will be enough boost for the time being too! Quote
Zeldoz Posted December 3, 2013 Author Posted December 3, 2013 .6bar spring will be fine mate.. I did that set that whilst I wasn't forged etc... ran fine bud. leave it at that boost till you have management. Exactly what i intend on doing! Fitting it this weekend hopefully! Quote
TurboTobz Posted December 3, 2013 Posted December 3, 2013 Think jay-c's idea is the way I'd personally play it also Quote
daniel_g Posted December 3, 2013 Posted December 3, 2013 I ran pretty much that setup for a while, was decent, you'll love it Quote
Zeldoz Posted December 3, 2013 Author Posted December 3, 2013 I ran pretty much that setup for a while, was decent, you'll love it I can't wait. I haven't been able to put my foot down for over a month. Since my decat wen't on then came fuel cut and boost creep. So going to 0.6 on a TD04 and being able to floor it.. I'll probably jizz everywhere, have a mental orgasm and loose it. (Let's hope not the final part) Quote
daniel_g Posted December 3, 2013 Posted December 3, 2013 Its a good feeling haha, mind and get some windscreen wipers for the inside, incase you get too excited andcan no longer control yourself. Quote
Zeldoz Posted December 3, 2013 Author Posted December 3, 2013 (edited) Its a good feeling haha, mind and get some windscreen wipers for the inside, incase you get too excited andcan no longer control yourself. This will happen. I'm going to take it down the country for it's first drive. If it all gets too much, i can bail into some woodland and finish myself off. Edited December 3, 2013 by Zeldoz Quote
daniel_g Posted December 3, 2013 Posted December 3, 2013 A small woodland creature normally does the trick...This will happen.I'm going to take it down the country for it's first drive. If it all gets too much, i can bail into some woodland and finish myself off. Quote
Zeldoz Posted December 3, 2013 Author Posted December 3, 2013 A small woodland creature normally does the trick... This could be interesting. Seeks google animal porn. Quote
daniel_g Posted December 3, 2013 Posted December 3, 2013 This could be interesting. Seeks google animal porn.Expect a knock on your door from a couple of angry RSPCA inspectors lol.This has went slightly off track now haha. Quote
Zeldoz Posted December 3, 2013 Author Posted December 3, 2013 Expect a knock on your door from a couple of angry RSPCA inspectors lol.This has went slightly off track now haha. LOL! They'd be fuming.... VERY off topic. Good news is.... I'll be buying the gaskets for the kit this afternoon... Fitting the kit will be at the weekend. Can't wait. Quote
jayc-glanza17 Posted December 3, 2013 Posted December 3, 2013 don't forget to run the vac pipe from top port of wastegate to turbo compressor port to run wastegate pressure. Quote
Zeldoz Posted December 3, 2013 Author Posted December 3, 2013 Jamie said leave the top nipple, and lower one goes to turbo...!?See pic..The top one I was told to leave, and the one the other side of the wastegate is I connect to turbo? Quote
jayc-glanza17 Posted December 3, 2013 Posted December 3, 2013 yes thats it, but it all depends on location of your wastegate to top or bottom.lol..so in that pic its the side port. Quote
Zeldoz Posted December 3, 2013 Author Posted December 3, 2013 yes thats it, but it all depends on location of your wastegate to top or bottom.lol..so in that pic its the side port.Yeah it'll be the side port when on! Is that oil line the only one I need? Quote
jayc-glanza17 Posted December 3, 2013 Posted December 3, 2013 oil feed yes their is only one.and then the oil return which im sure will come with your kit Quote
mark1991 Posted December 6, 2013 Posted December 6, 2013 ran mine 0.72bar if i am right, I ran it for 3 weeks before mapping and it got some amount of abuse... went fine tho Quote
