4efte crank has bigger counter weights.
not the same.
as for power, i dont know what it could take though id imagine any crap tune over 200hp will give it issues.
Phil
Depends what kinda build your doing, if its a stock build the crank would be the last of my worries. If its a forged motor then providing its static and dynamically balanced I see no reason why it can't take as much as a turbo crank.
Lol back to that old chessnut. That's purely the engine builder/owners decision, but balancing the rotating assembly is one of the very few procedures I would personally take in building a motor.
The list of machine work to carry out on an engine is quite defined and in all honesty I've not seen many people carry out half the things when building a proper blueprinted motor.
List of things I would advise when building a motor:
Crack test the block and head
Line bore the main bearings
Bore the cylinders
Check cylinder wall thickness
Ensure cylinders are 90 degrees to crank centreline
Crack test the crankshaft
Check crankshaft straightness
Crack test rods, if using stock items and shot peen
Balance rotating assembly
Thats all before you even get to check what size bearings you need or check oil clearances.
Edited by AdamB
Edited post mate.
Cranks tend to last quite a while if the pistons and rods are lighter, along with not going too mental on the rpm limits, but most peoples turbos will run out of puff before the crank rpm becomes an issue.
I'm sure RobH is still using the N/A crank and hes over 300bhp I think.
Edited by AdamB
The early N/A uses the 4ET crank and the later ones use the 4E crank mine is the 4E crank. The early ones are the same as the turbo cranks but the later 4efe used a different crank. going on this theres only the 1982 GT that has a different crank!
1999 glanza 13401‑11061
1982 GT 13401‑11060
1999 N/A 13401‑11061
1996 N/A 13401‑11061
