Zeldoz Posted December 10, 2013 Posted December 10, 2013 Basically TD04 my V last night, had to remove my air con pump for it to fit without fouling the turbo housing. Now i need a short 4 ribbed belt from EuroCarParts an they have loads in stock but want to give me the correct one, so i kinda need to know the measurement of a new belt? Does anyone have this information? I threw away my old one and the binmen came this morning, so i cant even work back with that which is irrating! Help haha! Want to be running this evening! Quote
Ollieh17 Posted December 10, 2013 Posted December 10, 2013 I bought one from IDWorkz,advertised as starlet non-aircon belt. So if you ask for a belt for a non-aircon starlet it should be spot on. Quote
daniel_g Posted December 10, 2013 Posted December 10, 2013 You could run it right now but youd have no PAS. Quote
Zeldoz Posted December 10, 2013 Author Posted December 10, 2013 You could run it right now but youd have no PAS. Yeah.. but, fuck that if i wanted a work out i'd buy a gym membership! Quote
daniel_g Posted December 10, 2013 Posted December 10, 2013 You started it up yet though ?It is quite heavy without PAS lol, had mine out my old GT for like 10 mins then fired it all back in haha. Quote
Zeldoz Posted December 10, 2013 Author Posted December 10, 2013 You started it up yet though ?It is quite heavy without PAS lol, had mine out my old GT for like 10 mins then fired it all back in haha. Not started it, Just thought i'd leave it i didn't finish until 10:30pm last night, so i thought after work i'll get a pump belt and then start it. But i need to read up about priming the turbo first. So anyone can get me either measurments OR the numbering off there short belt? Quote
Socks Posted December 10, 2013 Posted December 10, 2013 Any local motor factor can get you one mate.. Any 1.3 16v starlet without AC but WITH PAS.... Quote
daniel_g Posted December 10, 2013 Posted December 10, 2013 Get a VIN off a UK car, im sure someone on here will give you theres. And just go to the motor factors with that. Quote
Zeldoz Posted December 10, 2013 Author Posted December 10, 2013 Any local motor factor can get you one mate.. Any 1.3 16v starlet without AC but WITH PAS.... I said that, and he just said well i need some measurements or some numbering off your old belt...... Urghhh! Why are people so incompetent! Quote
daniel_g Posted December 10, 2013 Posted December 10, 2013 Or even a REG from a UK car will do. Quote
Socks Posted December 10, 2013 Posted December 10, 2013 I said that, and he just said well i need some measurements or some numbering off your old belt...... Urghhh! Why are people so incompetent! Go to a DECENT motor factors then lol Quote
Ollieh17 Posted December 10, 2013 Posted December 10, 2013 923mm length just by googling non aircon starlet belt Quote
fremyjay Posted December 10, 2013 Posted December 10, 2013 I'm sure some people forget Google exist haha923mm length just by googling non aircon starlet belt Quote
Zeldoz Posted December 10, 2013 Author Posted December 10, 2013 Go to a DECENT motor factors then lol True that. I'm sure some people forget Google exist haha Hmmmm.. legend! Quote
fremyjay Posted December 10, 2013 Posted December 10, 2013 True that. Hmmmm.. legend! damn right, common sense does wonders Quote
Zeldoz Posted December 10, 2013 Author Posted December 10, 2013 So ID-Workz sells them.. 4PK-925.. and CAMSKILL is 4PK-923... Quote
Ollieh17 Posted December 10, 2013 Posted December 10, 2013 I guess the last number is mm, 2mm would make very little difference. Quote
Zeldoz Posted December 10, 2013 Author Posted December 10, 2013 I guess the last number is mm, 2mm would make very little difference. That's what i thought. I could tension more on the 2mm i guess? Think i should go with the 925.. just incase its tight on the 923 one.. Quote
Ollieh17 Posted December 10, 2013 Posted December 10, 2013 Dont think it really matters, i bought mine from id, works fine Quote
fremyjay Posted December 10, 2013 Posted December 10, 2013 There is quite abit of movement so 2mm won't make a difference Quote
Ollieh17 Posted December 10, 2013 Posted December 10, 2013 Priming the turbo is easy, take the efi fuse out and try to start the car until oil comes out the return line Quote
Zeldoz Posted December 10, 2013 Author Posted December 10, 2013 Don't worry people I got him one haha, Save the day! Quote
