Zeldoz Posted December 16, 2013 Posted December 16, 2013 So looking at purchasing my wideband before i get it mapped. I would like to know if its essential or needed for when going EMB blue. Also, I found one which appears to be what im after on ID-Workz but it's much cheaper than any other. I need one which will monitor on idle as well as when on WOT... The main ones seem to be AEM & Inovative. Links; AEM;http://www.ebay.co.uk/itm/AEM-GAUGE-6-in-1-TYPE-WIDEBAND-UEGO-AFR-CONTROLLER-30-4100-/300976513214?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item46139920be Inovative;http://www.ebay.co.uk/itm/INNOVATE-MTX-L-AFR-Wideband-8-ft-Air-Fuel-Ratio-Gauge-3844-/300976513292?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item461399210c ID-Workz one; http://www.id-workz.co.uk/index.php?main_page=product_info&cPath=3_1118_8_212_213&products_id=497 Quote
Zeldoz Posted December 16, 2013 Author Posted December 16, 2013 the idworkz one is narrowband Explain? Quote
Ollieh17 Posted December 16, 2013 Posted December 16, 2013 http://www.competitiondata.com/air_fuel/pg2_wb_vs_nb.htm Quote
Chris_GlanzaV98 Posted December 16, 2013 Posted December 16, 2013 Ill be purchasing the aem one myself in the next few weeks alot of people use it from civics to skylines and seems to be a very accurate and reliable bit of kit Quote
Zeldoz Posted December 16, 2013 Author Posted December 16, 2013 http://www.competitiondata.com/air_fuel/pg2_wb_vs_nb.htm Perfect, So it's AEM or Innovative then! Quote
Chris Green Posted December 16, 2013 Posted December 16, 2013 Most people go for the AEM one. If you know what your target AFR's should be, then a simple innovate one will do. http://www.ebay.co.uk/itm/INNOVATE-DB-BLUE-LED-WIDEBAND-AFR-GAUGE-3793-/290874376359?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item43b976c0a7#ht_3078wt_993 Quote
Zeldoz Posted December 16, 2013 Author Posted December 16, 2013 Most people go for the AEM one. If you know what your target AFR's should be, then a simple innovate one will do. http://www.ebay.co.uk/itm/INNOVATE-DB-BLUE-LED-WIDEBAND-AFR-GAUGE-3793-/290874376359?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item43b976c0a7#ht_3078wt_993 That's a gauge only mate Quote
Chris Green Posted December 16, 2013 Posted December 16, 2013 It is yep, just showing the different options of wideband gauges. You don't need to have the 'sweeping bar'. Quote
Zeldoz Posted December 16, 2013 Author Posted December 16, 2013 It is yep, just showing the different options of wideband gauges. You don't need to have the 'sweeping bar'. Yeah, it's a gauge ONLY. No sensor or wiring including bud Quote
Turk Posted December 16, 2013 Posted December 16, 2013 Y do people hate innovate. Its pretty much the same shit. They use the same bosch sensor so they are as accurate as each other. And people go and pay more money for aem. Quote
Stu Posted December 17, 2013 Posted December 17, 2013 I've used an Innovate LM1 for years - have also used LC1's and LM2's. All great units and I've had no noticeable variations when comparing against dyno room gear. Quote
TurboTobz Posted December 17, 2013 Posted December 17, 2013 Dont over look the plx dm6 I personally couldn't monitor a live wideband while boosting and trying to keep eyes on road the plx will keep peak and minimum values for you stored map them out on a graph and show them on colourful lights like an aem. Rob-h on here with the insane 4efte n/a said about them I took his advise and got one it can be linked with 6 other modules to show thinfs like boost egts inlet temps oil pressure and temps etc etc.Doesnt need calibration and uses the bosch sensor same as most widebands Youtube themAlso supports data loggingAnd can be linked to ecus Quote
mikey4410 Posted December 17, 2013 Posted December 17, 2013 Innovate are superb.very accurate.trouble free Quote
Jamie_VF22 Posted December 17, 2013 Posted December 17, 2013 Dont over look the plx dm6 I personally couldn't monitor a live wideband while boosting and trying to keep eyes on road the plx will keep peak and minimum values for you stored map them out on a graph and show them on colourful lights like an aem.Rob-h on here with the insane 4efte n/a said about them I took his advise and got one it can be linked with 6 other modules to show thinfs like boost egts inlet temps oil pressure and temps etc etc.Doesnt need calibration and uses the bosch sensor same as most widebandsYoutube themAlso supports data loggingAnd can be linked to ecus Any links toby ? Quote
TurboTobz Posted December 17, 2013 Posted December 17, 2013 http://www.plxdevices.com/product_info.php?id=WDBDSMAFR_DM6 Quote
Jamie_VF22 Posted December 17, 2013 Posted December 17, 2013 http://www.plxdevices.com/product_info.php?id=WDBDSMAFR_DM6 Spot cheers mate Quote
5e colin Posted December 17, 2013 Posted December 17, 2013 here mate 150e delivered cant go wrong http://www.ebay.ie/itm/DEPO-racing-52-mm-Smoked-Blue-LED-color-AFR-Air-Fuel-Ratio-Gauge-w-Bosch-sensor-/300752729917?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item460642773d Quote
Chris Green Posted December 17, 2013 Posted December 17, 2013 Heard Depo is wild dodgey especially their EBC's. Quote
TurboTobz Posted December 17, 2013 Posted December 17, 2013 here mate 150e delivered cant go wrong http://www.ebay.ie/itm/DEPO-racing-52-mm-Smoked-Blue-LED-color-AFR-Air-Fuel-Ratio-Gauge-w-Bosch-sensor-/300752729917?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item460642773dfound this seller to be fastest I got my plx from them came next day as its free next day dlivery worth noting they are also cheapest they sell a lot of different gauges Quote
triple j Posted December 17, 2013 Posted December 17, 2013 Depo ones are dodgy, my aem one is going strong well over a year now no problems. Quote
TurboTobz Posted December 18, 2013 Posted December 18, 2013 Think I sold my plx to monty-1991 name maybe slightly different maybe worth asking how he finds it Quote
Turk Posted December 27, 2013 Posted December 27, 2013 (edited) The plx dm6 gen3 looks the bomb!!!! I think ill get one when my student loan goes through Edited December 27, 2013 by Turk Quote
