Hey recently got myself my first glanza v 96 :) love it , does need a bit of wurk done to it , exterior and suspension, got a hks fcon ecu cumin also a turbo timer and got a few other things planned, but before that wanting to give her a good full service get it threw the mot and do things as I go along, taking her off the road in jan to get her al running good, was just wondering how much engine oil, coolant and gear oil? Also is there any other small things I should replace whislt doin a service?
Cheers
Dusty :)
Fluids
Oil 2.8 litres
Coolant Toyota Long Life
Gearbox oil - ive heard alot about redline oils dont quote me but i believe its 75w90 ? best to double check i think this is oem reccomendations
Powersteering/clutch and brake fluid use oem spec
Plugs ngk iridium heat range 7 should do
give the cv joints a good check over as these tend to go quite easily check pads and disks for wear and just general look over
hope this helps ! :)
About 3L for the gearbox and about 4L for the engine, will see you with some left over. Get 5L of coolant from Toyota, that will be more then enough.
Edited by DevonGT
Wow that's a fair jump guys lol 2.8 to 4 l? 2.8 rang a bell sure I've seen it sum where else thinking of it
Engine oil -2.8L
Gear box oil?
Coolant?
Just wantin to order enough for one service kno it won't be to the exact amount but as close to it can be
Getting cam timing and aux belts changed also is the thermostat a good thing to change? Red sum where to a braided oil feed is a good replacement while she's off the road getting a bit o tlc
Cheers
Dusty :)
Edited by Dusty
Buy 5l of gearbox oil, or 4 if you can which would be plenty. To get the exact amount there is a bolt on the side of the gearbox, take that bolt out and when oil pours out while filling up from the top theres enough oil in there. then you have a spare few litres to top up if needed
Engine oil -2.8L
Gear box oil?
Coolant?
Cheers
Dusty :)
The figures i quoted were not the capacity but what you should buy.
Ok cheers all the same guys :)
What about the coolant anyone got a link you can buy this online?
Is thermo stat aux belt timing belt check cv joint and driveshafts anything else I should look at or replace just to be sure, is a braided oil feed a good upgrade/replacement?
I live in sw Scotland out in the sticks lol no local dealers the closest I've seen is this http://www.amazon.co.uk/TOYOTA-COROLLA-FREEZE-COOLANT-CONCENTRATED/dp/B00ETCWPFS/ref=sr_1_2?ie=UTF8&qid=1387317400&sr=8-2&keywords=toyota+red+coolant ? Is this any good ?
Buying ignition upgrade kit from TD it has Leeds plugs dist cap
Looking at timing belt aux belt
Thermostat
Look at driveshafts and cv joints ( noticed a grinding noise when turning left could this be cv joint?
Check brake pads
Fuel pump upgrade
Thinking of braided oilfeed just to be safe
Taking her off the road in jan wanting to get all the parts ordered so everything's done at once .
Anything else I should add to the list while getting the work done on it?
Any help atall much appreciated :)
Cheers
Dusty :)
Edited by Dusty
i tend to look after the little things on these cars to help them run smoothly.. after
you have given her a good service, clean the things below..
ICV - idle control valve - take apart (look for tutorial on here)
ATS - air temp sensor - wipe off gunk with a cloth
CTS - coolant temp sensor - scotch pad
and make sure you top up the oil level after you start it after the service... the dipstick
may read full but once its started after the service, it will drop to fill the oil filter etc...
Edited by corofin12345
