corofin12345 Posted December 18, 2013 Posted December 18, 2013 lads, why are people saying head gasket here..?? its oil thats pissing out, not water.! running on 3 cylinders could be anything.. find the source of the oil leak first and go from there Quote
Kingcarr Posted December 18, 2013 Author Posted December 18, 2013 its either head gasket or its put a rod through the block... head gasket sounds likely as I was having issues with misfires at top end which could have been loss of compression or oil/water entering the cylinder!?! Quote
daniel_g Posted December 18, 2013 Posted December 18, 2013 lads, why are people saying head gasket here..?? its oil thats pissing out, not water.! running on 3 cylinders could be anything.. find the source of the oil leak first and go from thereThere are oil ways in the head aswell. I just said it sounds like a HG failure, not written in stone, however it explains the oil, bang & running like shit straight after due to loss of comp.Or it could be a rod out, but the OP was told by a mechanic that the block was intact. Quote
corofin12345 Posted December 18, 2013 Posted December 18, 2013 There are oil ways in the head aswell. I just said it sounds like a HG failure, not written in stone, however it explains the oil, bang & running like shit straight after due to loss of comp.Or it could be a rod out, but the OP was told by a mechanic that the block was intact. really wasnt clear in my last comment sorry... i dont think ive ever heard or seen a catastrophic hg failure like that.. i ment to say, theres no point ripping off the head assuming its the hg... he mentioned oil around alternator and brake cylinder... id lean more towards an oil pump failure and the belts then threw the oil up there... loss of oil pressure could of then blowin something else so it could be a few problems (all this can happen in seconds).... source the problem then comp test the engine Quote
Kingcarr Posted December 18, 2013 Author Posted December 18, 2013 my mobile mechanic mate couldn't see anything obvious, and he has text me today to say that its quite possibly the HG. hes busy until after xmas, so im pretty much on my own lol Quote
Kingcarr Posted December 18, 2013 Author Posted December 18, 2013 I would but its dark before I leave for work and dark when I get back, could do with getting it jacked up and getting under to see the back of the block. Quote
